[SOLVED] Macro redefinition in 2.6.1 shaders
Our shader compilers are complaining about redefinitions of SCALE_UV and DEPTH_RESOLUTION_ZERO when we run on GPUS other than NVIDIA (for which the GLSL compilers are notoriously slack).
I doubt this line will be working the way it was intended in ssr.frag or ssrtgi.frag:
#ifndef SCALE_UV || DEPTH_RESOLUTION_ZERO
Hi Greg,
To remove this warning you will need slightly patch the #ifndef SCALE_UV || DEPTH_RESOLUTION_ZERO define, so it will look more like this:
	#undef SCALE_UV // add this line
	#undef DEPTH_RESOLUTION_ZERO // add this line
	#define SCALE_UV 1.0f
	#define DEPTH_RESOLUTION_ZERO 0
#endif
Thanks for the report!
  • silent changed the title to [SOLVED] Macro redefinition in 2.6.1 shaders
Shouldn't the line I quoted be something like
#if !defined(SCALE_UV) || !defined(DEPTH_RESOLUTION_ZERO)
then?
Greg,
I believe proposed fix should be enough. I've tested on Intel Iris Pro 580 with latest Windows 10 drivers and can't see any warnings in console anymore.
This fix will be also available with an upcoming SDK update.
Yes, doing the #undefs will prevent the warnings. But have you tested that the code actually does what you intend it to? I expect it's ignoring everything after SCALE_UV because an #ifdef can only apply to a single token. And even if _your_ compiler is broken enough to do what you want here, other compilers are likely to behave differently or refuse to compile it.
