[SOLVED] 2.6.01 to 2.6.1.1 VR projects issues
when I updated my projects from 2.6.0.1 to 2.6.1.1
I found that as long as the project needs to be run in VR environment it will throw an error .
even for the vr_tempate and the oil_refinery demo.
what should I do to make the 2.6.0.0.1 VR ready projects can be run after updated to 2.6.1.1?
Thanks.
Hello, de-Roo.Lukas
Please keep in mind that after upgrading C++ based project, you need to manually change links to "Additional Library Directories" & "Additional Include Directories" in properties of your Visual Studio Project
Thank you!
NO, what is worse, when I uninstall the version 2.6.1.1  and come back to use 2.6.0.1 SDK
 the VR function in my 2.6.0.1 backup version works but cigi function doesn't work.
Instead when I use 2.6.0.1 SDK to run 2.6.1.1 cigi demo it works, but 2.6.0.1 cigi demo doesn't work
it seems that when I download 2.6.1.1, something has changed even I uninstall the 2.6.1.1 and comes back to 2.6.0.1
when I rebuild the vr_template project which has been updated from 2.6.0.1 to 2.6.1.1  in 2.6.1.1 SDK,
build successfully but when I run
it has such errors:
Could you please provide us screenshot of your project property pages?
For a project updated to 2.6.1.1 SDK it should be looking similar to this:
Sorry for any inconvenience caused
Thanks, your advice is really helpful. it works.
  • silent changed the title to [SOLVED] 2.6.01 to 2.6.1.1 VR projects issues
