Couldn't find the right matrial
Hi ,
I find a big problem that troubled me. If there are two project in the data folder, they all have the same name material testMaterial(the material that create by myself).
If I load one project and want to show a picture to the testMaterial, the picture could not be loaded.After remove the other project, the picture could be loaded.
This means only one project can be in the data folder.
Regards,
Willam
Hello William,
I'd like to ask you a couple of questions:
  • which SDK version you're using?
  • by projects you mean .world files?
  • is your test material created in editor? or you've made it manually (created XML file)
In general there's no such limitation. You can use same material in any number of projects.
