Standarize file names for use in SDK Broswer
I observed that SDK Browser use file named "main_x64.exe" for "Edit Contetnt" but it takse "PROJECT_NAME_x64.exe" into "Assemble project". It could be very helpful to standardize it and use just one file convention.
Cheers,
Jan
Hi Jan,
Editor2 is always started with empy logic application (main_x64) to avoid any specific app logic that would interfere the Editor2 normal work. We are still thinking on a better solution that will allow seamless Editor2 load into the existing application.
12 hours ago, silent said:
Hi Jan,
That's good solution if you not use own code implementation in the c++ code as for e.g. exporting classes to US. Then to work in Editor2 you need to have modified version of base code. But as you write it is useful to have clean code too ... so maybe as a solution it could be another checkbox or list to choose pattern of file names to use with SDK Browser ?
Hi Jan,
Could you please try to build your application into <bin> folder of the project, launch it as usual and later execute console command editor2_load? Will editor load in that case?
3 hours ago, silent said:
Hi Jan,
Hi @silent,
That's works and open Editor2. Also it is possible to rename execution file to start Editor2 or Assamble modified project via SDK Browser.
