[SOLVED] Create mesh from reference node don't work
when i try create mesh from node reference in editor it create empty mesh file.
Create FBX from node reference work.
it's intended behavior because node reference can contain anything (Light, Particles, Terrain etc). Create FBX uses different logic and it supports more than geometry export.
You still can open Node Reference and create mesh from the desired object.
Ok, i thought that it worked before.
For ours case, it can be do via create FBX, i guess.
Thanks.
  • morbid changed the title to [SOLVED] Create mesh from reference node don't work
