de-Roo.Lukas Posted May 31, 2018 Posted May 31, 2018 (edited) What is the easiest way to query the Latitude / Longitude / Altitude of an object during runtime? I am creating a pseudo map interface using a high altitude ortho camera (looking straight down). I want to drop an object and then write the latitude / longitude / altitude of the object to an xml. I currently do not know the best way to determine these coordinates of the object after it is placed arbitrarily in the world. Edited May 31, 2018 by de-Roo.Lukas
unclebob Posted June 1, 2018 Posted June 1, 2018 Hi, The engine itself operates only in cartesian coordinates so you have to provide additional information in order to get Lat / Lon / Alt coordinates on specific datum. You can go two ways: 1. If you have geo-referenced raster data and you know what projections it uses then you can use DatasetRasterPosResolver::getGeodeticPosition to get Lat / Lon / Alt coordinates from raster coordinates. 2. If you don't care about specific projection then you can use place GeodeticPivot somewhere in the world, set it's geodetic origin and use GeodeticPivot::mapFlatToGeodetic and GeodeticPivot::mapGeodeticToFlat for conversion between geodetic and cartesian coordinates.
