2.7.1 AppVive Load in Debug Mode
I have difficulty  in automatically load the AppVive plugin in debug mode in 2.7.1
in the previous version, I just need to use Engine::get()->addPlugin("AppVive");
however, in 2.7.1 there will be an error.
Now I can only run AppVive in the release version.
When I use  Engine::get()->addPlugin("AppVive");
it showed the following error:
I have a debug dll in my bin folder
Hi Lukas,
Can you check this behavior if you will specify command line parameter -extern_plugin AppVive (and remove  Engine::get()->addPlugin("AppVive");) from your code?
I have already input -extern_plugin AppVive in the command line, but that only works for the release version.
when I run debug in  VS,  no plugin will be loaded.
Hi Lukas,
Sorry, but it seems that I couldn't reproduce this behavior. My steps were following:
  1. Create new project via SDK Browser;
  2. Open folder with a project;
  3. Modify launch_debug.bat
    leave only AppVive plugin: -extern_plugin AppVive
  4. Launch bat file.
Plugin is loaded correctly.
Please, make sure that you have latest SteamVR installed.
