[SOLVED] How is s_water_time implemented
I would like to ask how the s_water_time shader parameter is implemented. As far as I can tell it is a seconds based timer.
If my assumption is correct, my question would be, if that timer is resetted to zero after a certain amount of time ?
I'm asking this, because I'm working on a displacement map based wave implementation and I know that a seconds based timer which is never resetted is running into precision problems after 2-4 weeks or so.
Thanks
Helmut
Hello Silent,
thank you for that piece information. I'm indeed using a ObjectWaterMesh but I can easily implement a timer for my use case. Just wanted to know how s_water_time behaves :-)
Cheers,
 Helmut
  • silent changed the title to [SOLVED] How is s_water_time implemented
