steve3d Posted September 2, 2010 Posted September 2, 2010 in ung_x86.exe can use a flag to indicate which path to exclude, so, every time I want to exclude the editor directory, then I use -x editor, in fact , it really excluded the editor directory, but it also excluded the file core\gui\gui_editor.png, because it's filename contains editor. so the ung.exe should only exclude directory, not based on the filename, or, ung.exe should both flag to exclude a directory or a filename pattern.
frustum Posted September 3, 2010 Posted September 3, 2010 in ung_x86.exe can use a flag to indicate which path to exclude, so, every time I want to exclude the editor directory, then I use -x editor, in fact , it really excluded the editor directory, but it also excluded the file core\gui\gui_editor.png, because it's filename contains editor. so the ung.exe should only exclude directory, not based on the filename, or, ung.exe should both flag to exclude a directory or a filename pattern. Internally we use following command to exclude editor: ung -d core -x core/editor
