WorldTransformPath / Tracker Path
I'm looking to create a animation using the Tracker tool. I have created and saved a .path file using the tracker tool in the editor. This will then be used to create camera animation to play through c# script.
Currently i get the error:
Wrong first magic 0x6d783f3c in "../data/paths/camerapath1.path"
using code:
transformPath = new WorldTransformPath(path,1);
Is this the wrong class to use with loading path files? or is there a better way to create camera animation paths?
I've looked at: https://developer.unigine.com/en/docs/2.7.1/editor2/tools/tracker/run/
but the c# api doesn't have tracker class?
Hi Marc,
There is no possibility to save .path from Tracker currently. .path files can be only exported from 3ds Max plugin. If you already have a track for camera you can play it via Tracker, but you will have to write a custom wrapper in Unigine script and then call functions from C++ / C# API.
We do have plan to improve that in future, but I can give an exact ETA for this, sorry.
