de-Roo.Lukas Posted July 6, 2018 Posted July 6, 2018 (edited) Hi, I have two graphics cards in my computer, but I found that even the first one is 100% utilization, the second one is still 6 %, it seems that only one graphics card works. How can I ask Unigine to use both cards? Thanks. Edited July 6, 2018 by de-Roo.Lukas
silent Posted July 6, 2018 Posted July 6, 2018 Hi Lukas, With TAA enabled SLI / Crossfire will not give you 2x performance boost due to complexity of deferred rendering. In worst-case scenario you can even get lower framerate that it was before. Please, keep in mind that it will work only in desktop mode (not in VR) and only in DX11 and fullscreen. Open nVidia Control Panel (right mouse click on Windows desktop): Select Configure SLI, Surround, PhysX in the left menu; Enable SLI (select Maximize 3D Performance radio button and click Apply): Select Manage 3D Settings; On Program Settings tab click Add button; In opened Add window click Browse button; Via file dialog select your *.exe application and click Open button. In settings change SLI Rendering mode to Force alternate frame rendering 2: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
dracik Posted April 13, 2020 Posted April 13, 2020 On 7/6/2018 at 7:08 AM, silent said: Hi Lukas, With TAA enabled SLI / Crossfire will not give you 2x performance boost due to complexity of deferred rendering. In worst-case scenario you can even get lower framerate that it was before. Please, keep in mind that it will work only in desktop mode (not in VR) and only in DX11 and fullscreen. Open nVidia Control Panel (right mouse click on Windows desktop): Select Configure SLI, Surround, PhysX in the left menu; Enable SLI (select Maximize 3D Performance radio button and click Apply): Select Manage 3D Settings; On Program Settings tab click Add button; In opened Add window click Browse button; Via file dialog select your *.exe application and click Open button. In settings change SLI Rendering mode to Force alternate frame rendering 2: Thanks! Hi, do you know also how to set this up for crossfire support for Radeon graphics cards? I can't find a way to turn on crossfire support for unigine editor...
silent Posted April 13, 2020 Posted April 13, 2020 Crossfire works only for the fullscreen applications, so I doubt that it would work for the Editor (it's not a fullscreen app). How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
semenov.anton Posted April 7, 2021 Posted April 7, 2021 (edited) Hello! I am interesting, have Unigine 2.7.2 OpenGL some options to run 2 instances of Unigine on 2 different GPU without SLI? Edited April 7, 2021 by semenov.anton
silent Posted April 7, 2021 Posted April 7, 2021 You can do that trick with the latest engine versions (noy 2.7.2) and unfortunately only with DX11 API (under Windows). In theory it should be possible to setup Linux xserver that way so the each individual GPU will run only on a specific display and you can therefore load different GPUs by specifying different $DISPLAY variables on engine start-up. We never did it before on our side, so I can't really say how exactly you need to configure your system in order to achieve that behavior. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
