Rotorwash on water
I'm trying to implement a rotor wash effect on water, like here:
 Image associée
The vapor effect is quite "easy" to fake with particles, but I can't find a way to simulate the waves/ripples effect. I'm not trying to have the 3d effect, but rather the "water blown away" with strong ripples.
As far as I can tell, the particle_base material can't project ("decal") onto the water. So how should I do that?
Thanks.
Indeed, a "Decal" object can project onto the water, but not the particles. This mean I would need to reimplement a small particles management in code, animating the Decals.
If this is currently the only solution, I would suggest for future evolution to enable "project on water" for basic particles. Or adding "Decal particles" type to the list of emitted particles.
Thanks !
Amerio,
Please, check the Oil Platform demo (ship. Particles can be rendered into a texture that decal can use to apply on Water. But you need to be careful in terms of performance, since this feature is really CPU/GPU intensive.
Hi, I've read ship.h and others sources from this demo, and I still can't understand the trailing foam effect is done. I understand what you meant, I just couldn't find in the code how it's done (more documentation in code would be a nice touch, though, also explaining the relation with all the parameters set in the editor)
Thanks for your support
