Change the particle color with time
I want to change an emitter's particle's color from light to dark with time.
Not change all the particles, just change part of the particles' color.
Is it doable?
Thanks
Usage of 2 separate ObjectParticles instances (one with color variation, one without) and usage of 2 particle_base materials with different attenuation textures assigned ?
Hello Lukas,
you also can do it via tracker tool. Just change color parameter of a material over time: https://developer.unigine.com/en/docs/2.7.1/editor2/tools/tracker/basics/
You'll need a single track that controls diffuse color of particles material. In Tracker tool select Add -> material -> parameterColor.
Hi, morbid
But if I change the material color, all the particle's color will change, I don't want all the particles' color change,   I just want part's of the particles' color change.
For instance, if a new particle was emitted, it's color is white, after 20 seconds it changed to back.
So it means all the new particle emitted has the same color, after the 20s, they will change to another color.
particle_base material attenuation texture provides this
