nathank Posted April 28, 2011 Posted April 28, 2011 I'm trying to use setWrapRepeat on a sprite to tile the texture but it doesn't seem to have any effect, no matter what value I pass in as a parameter. The docs say it requires a positive number to enabled tiling, so I call it with 1, and then use setWidth/setHeight to resize the sprite. The texture just stretches instead of tiling. Is there some other way I should specify the size to get tiling to work or is this function broken?
frustum Posted April 29, 2011 Posted April 29, 2011 You should modify sprite texture coordinates to see the effect. Try WidgetSprite::setTexCoord(vec4(0.0f,0.0f,4.0f,4.0f)) function;
