Terrain tools
I do not know if this is a problem for our terrain only (ESQ), but since version 2.7.x the terrain adjustment tools are a little "insensitive"
Smooth smooth didnt respond under brush size 12.
https://www.youtube.com/watch?v=A3F_kw1VGf8&list=UUEGmquV5a4e_LoJUbVnckmw&index=10
Add and substract tool works only with some points, some does not touch, which makes it impossible to fine-tune the terrain.
https://www.youtube.com/watch?v=xQwJmCgUl_I&list=UUEGmquV5a4e_LoJUbVnckmw&index=9
Edited by m.c.
Hello m.c.,
we didn't make any changes to terrain brushes.
Smooth will do its job only if it has different heights to blur. So you need to make brush size bigger.
Could be caused by low terrain density. Which world you're editing? I'd like to take a closer look at this.
Thank you!
We are editing terrain in esqworld.world. Difference to previous versions is, that now we edit terrain global, but before it was object terrain. So little bit different behaviour is maybe caused by this. Terrain is migrated, so it has same resolution as before. Only problem we are facing now is, that we are not able to do small terrain finetuning as before.
Edited by demostenes
