DOF on Each Camera
Can you somehow setup each camera in your scene to have different DOF properties?  I'd like to have each cut scene for the intro to have different DOF settings.  Thanks.
Hi Trey,
cameras have no unique DOF settings.
You can switch between different Depth of Filed parameters using render_settings files or change DOF in runtime. Please check the Samples\camera_effects\depth_of_field.world.
You also can change DOF values using tracker, check dof parameter.
https://developer.unigine.com/en/docs/2.7.2/editor2/settings/render_settings/
https://developer.unigine.com/en/docs/2.7.2/editor2/settings/render_settings/dof/
ok thanks.  Didn't think about the tracker!  This would be where I would store my animation for each camera anyway, thanks.
