shichao Posted September 12, 2018 Posted September 12, 2018 i use setplayer in update() and i grab frames after i call setplayer i found the frame i grabbed was not changed. about one or two frames later , the frame changed. but i want after i call setplayer, the frame change immediately。 is it possible?
silent Posted September 12, 2018 Posted September 12, 2018 Could you please provide a code that you are using? Right now it's hard to say what is going on, without seeing the actual code. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
shichao Posted September 13, 2018 Author Posted September 13, 2018 20 hours ago, silent said: Could you please provide a code that you are using? Right now it's hard to say what is going on, without seeing the actual code. Thanks! virtual int update() { //2 if the first breakpoint is hit and add a breakpoint here to see whether the frame changes or not. sometime it not change static int count = 0; Game *game = Game::get(); float time = game->getTime(); if (count % 50 == 0) { //1 add a breakpoint here if setplay is called float x = 0;// sinf(time * 1.0f) * 4.0f; float y = 8;// cosf(time * 1.0f) * 4.0f; float z = 1.0f;//2.0f +sinf(time * 3.0f) * 1.0f; player->setWorldTransform(setTo(UNIGINE_VEC3(x, y, z), UNIGINE_VEC3(0.0f, 0.0f, 0.0f), vec3(0.0f, 0.0f, 1.0f))); //player->setFov(60.0f + sinf(time * 2.0f) * 25.0f); game->setPlayer(player->getPlayer()); Log::message("0 setPlayer %d\n", count); } else if (count % 50 == 25) { float x = 1;//sinf(time * 1.0f) * 4.0f; float y = 4;// cosf(time * 1.0f) * 4.0f; float z = 1.0f;// +sinf(time * 3.0f) * 1.0f; player->setWorldTransform(setTo(UNIGINE_VEC3(x, y, z), UNIGINE_VEC3(0.0f, 0.0f, 0.0f), vec3(0.0f, 0.0f, 1.0f))); //player->setFov(60.0f + sinf(time * 2.0f) * 25.0f); game->setPlayer(player->getPlayer()); Log::message("1 setPlayer %d\n", count); } else{ Log::message("2 setPlayer %d\n", count); } count++; return 1; }
shichao Posted September 13, 2018 Author Posted September 13, 2018 replace the file in the path :samples\Api\Nodes\Players and 1.jpg: before the setplay 2.jpg: the next frame after the setplay called, it not changes although it not appear frequently 3.jpg: the next frame after the setplay called, it changes. but i want next frame always change what should i do? Players.cpp
andrey-kozlov Posted September 13, 2018 Posted September 13, 2018 Hello, shichao The behaviour you observing is due asynchronyous nature of GPU. It's not really up to engine what you see on your monitor at this very moment. It's more about complicated interaction between engine, OS and drivers. Try grab screenshot programmatically (like Render/Screenshot sample does). That's guaranteed that camera position at screenshot will be the last one you've set.
shichao Posted September 13, 2018 Author Posted September 13, 2018 15 minutes ago, andrey-kozlov said: Hello, shichao The behaviour you observing is due asynchronyous nature of GPU. It's not really up to engine what you see on your monitor at this very moment. It's more about complicated interaction between engine, OS and drivers. Try grab screenshot programmatically (like Render/Screenshot sample does). That's guaranteed that camera position at screenshot will be the last one you've set. i not found the sample in SDK 2.6 maybe the follow code is right? while(1){ engine->update(); engine->render(); ImagePtr buffer = Image::create(); image->create2D(getWidth() * 2, getHeight(), Image::FORMAT_RGB8); context->CopySubresourceRegion((ID3D11Texture2D *)texture->getD3D11Texture(), 0, 0, 0, 0, render_targets, 0, NULL); texture->getImage(buffer); buffer->convertToFormat(Image::FORMAT_RGB8); image->copy(buffer, getWidth() 0, 0, 0, getWidth(), getHeight()); engine->swap(); } but grab images in main loop cost a lot time. what i do now is put the grab code in another thread so cause the problem
andrey-kozlov Posted September 13, 2018 Posted September 13, 2018 For observing purpose you could catch the situation with breakpoints and then call the function saving image from debugger. At my machine it causes flushing image at screen as well
