BVH Coordinate Euler to Unigine Quat
How can I transfer a vec3(angleX, angleY, angleX) in BVH coordinate system to Unigine quat?
Thanks
sorry, maybe I didn't say it clearly.
Now I have a Euler data got from BVH coordinate system , Y:up,  X:right Z:forward
the data was received from another device, not directly from Unigine
Now in Unigine, I want to use this data, and I need to transfer it to Unigine Coordinate quat
The link you showed me, works for vec3() that comes from the Unigine Coordinate system
In my case, it seems that I need to do some transformation from BVH coordinate system to Unigine Coordinate system.
after that, I can use quat you showed to me.
Edited by de-Roo.Lukas
Hi Lukas,
Per the Biovision format, the order of rotation is Y,X,Z
So I guess you can get the equivalent quat by multiplying the 3 rotation: quatbhv = quat(0,1,0,y)*quat(1,0,0,x)*quat(0,0,1,z)
(or maybe reverse the order, you'll have to check yourself).
Hope this helps.
Thanks, Amerio
in your solution: quatbhv = quat(0,1,0,y)*quat(1,0,0,x)*quat(0,0,1,z),
y is for the Y axis in Unigine X is for the X axis in Unigine
however, the angleX,angle Y angleZ now I have, are all from BHV coordinate system, it is not the angle X for Unigine x axis. ,or angleY for Unigine Y axis.
and  I just do not know who to convert angleX in BHV x axis to "angleX" in Unigine x axis.
19 hours ago, silent said:
Hi Lukas,
Default quat constructor from vec3 is not working in your case? https://developer.unigine.com/en/docs/2.7.2/api/library/math/class.quat?rlang=cpp&words=quat#quat_constvec3
Hi, silent
I have a set of Euler angles rotation from BVH coordinate system
just as the followings:
AngleX, AngleY and AngleZ in the following coordinate system
all I current have are three numbers, which got from other device
how should I convert the rotation Euler numbers to Unigine quat?
I don't think quat(AngleX,AngleY,AngleZ) works, as it is for the Unigine coordinate system, right?
Hi Lukas,
Depends on what is the actual axes in your case you might need to change the X Y Z and play with +/- signs in order to get the correct results. Here is some useful links:
  1. https://stackoverflow.com/questions/16099979/can-i-switch-x-y-z-in-a-quaternion
  2. https://gamedev.stackexchange.com/questions/129204/switch-axes-and-handedness-of-a-quaternion
  3. https://math.stackexchange.com/questions/2379468/swapping-quaternion-x-and-z-values
UNIGINE's coordinate system is described here: https://developer.unigine.com/en/docs/2.7.2/start/programmer/basics_objects (basically it's right-handed Cartesian ).
