problem loading UI files
This is a stupid question, Im sure Im doing something wrong here. I have an empty world test.world and this test.cpp:
Gui gui;				// gui
UserInterface ui;
int init() {
   create_scene();
void create_scene() {
gui = engine.getGui();
ui = engine.gui.addUserInterface(gui,"test.ui");
return "";
This is test.ui
<ui version="1.0">
<button name="test_butt" pos_x="10" pos_y="10" export="1"/>
</ui>
But when I run it, I get this error:
Loading "test.cpp" 0ms
Loading "test.world" 0ms
Interpreter::setVariable(): unknown variable "test_butt"
Whats my mistake here? I have been looking in the demos and I cant see any extra step that I could be missing.
No GUI knowledge at all, so just a blind guess: Widgets (e.g. button) might have to be embedded into Containers (e.g. window, vbox). See docmentation section "Programming\Gui\UI Files" and search within SDK data subdirectory for *.ui samples.
Maybe something like
<ui version="1.0">
<window name="window" /* required parameters */>
</window>
</ui>
Nope, that just added another error: Interpreter::setVariable(): unknown variable "window", besides the one for test_butt. tried copying ui_01.ui from samples and I got the same error for each widget declared there.
Post your test scene as zip file, I will take a look into engine source
The world is empty:
test.world
<world version="1.12"/>
Also I have experienced this error on every application I have made with unigine, with empty worlds or not.
Solution is to define corresponding widget variable with same name as stated in export argument in test.cpp
WidgetButton test_butt;     // will be initialized by engine.gui.addUserInterface(gui,"test.ui") call
Gui gui;
UserInterface ui;
int init() {
   create_scene();
return "";
Hmm, that crossed my mind, but it wasnt explicitly explained in the manual, so I thought it was a bad idea.
Ok! That fixed the error, but still the button is not visible.
Maybe you have to set button text. Also there are working samples data\widgets\ui_00/01
Nope, setting the text doesnt fix it. Button still invisible.
Maybe you use different namespaces in your class/package and ui-layout? (Try use custom package, not global)
Correct ui-part:
<vbox name="Source::MainMenu::mainPanel" export="1">
<sprite align="background" texture="source/textures/gui/window.png"/>
Package-part:
namespace Source
namespace MainMenu
	WidgetVBox mainPanel;
Also see data\samples\widgets\ for template
Again, no buttons.
Here are my project files with latest updates:
test.cpp:
namespace Testing {
Gui gui;				// gui
UserInterface ui;
int init() {
   create_scene();
void test_callback() {
   printf("test \n");
int update(){
       test_butt.setCallback(GUI_CLICKED,"test_callback");
return "";
test.ui:
<ui version="1.0">
<button name="Testing::test_butt" pos_x="10" pos_y="10" export="1">
	<text>Press me</text>
</button>
<button align="overlap" pos_x="80" pos_y="110">
	<text>Press me 2</text>
	<callback type="clicked">Testing::test_callback</callback>
</button>
</ui>
and an empty world, test.world:
Well, seems that the problem is not related to UI files only. Added a button in code and it is not visible neither:
test_butt2 = new WidgetButton(gui,"Next");
   test_butt2.setPosition(20, 80);
   gui.addChild(test_butt2,GUI_ALIGN_OVERLAP);
also tried adding a PlayerSpectator and creating lights, but didnt worked. Do i need to include some specific unigine header or something?
You need to add your button to gui also:
       gui.addChild(test_butt, GUI_ALIGN_OVERLAP); // add your button
       return "";
That solved the problem. And the previous post about missing button when created via code, solved too, when I removed the namespace. Weird, isnt it?
Now, isnt UI files suppossed to do all that work for me? If I have to create the variables and also add them manually to the gui, then Im just saving a couple of lines for each gui element.
Yes, you are. Also you could describe all form in UI with one root element, for example:
       </button>
       </button>
<button name="Testing::test_butt2" pos_x="10" pos_y="10" export="1">
       </button>
       </button>
</vbox>
and then you need use only:
gui.addChild(mainPanel, GUI_ALIGN_OVERLAP); // add all your buttons with container
and all you buttons will be added automatically
