[SOLVED] Import animation without mesh triple bones from fbx
when import fbx that contain only animation bones without mesh, then animation have duplicated bones by 3.
Orig fbx have 156 bones, imported animation have 468 bones.
Setting: import_animation.png.6e54bbd98c12a33848737b21895aaad0.png
Source fbx: male__JumpWalkStart_RU.fbx
Thanks
Honya
Hello honya,
Thank you for your feedback, i've added this issue to our internal bugtracker, unfortunately, for now, i can't give you any ETA on when it will be fixed. Could you please specify if this issue is a showstopper in your workflow
Thanks
Just now, vvvaseckiy said:
Hello honya,
Thanks
Currently it is , we did masive change to our animation system, switching to root motion animations and we dont know about any other way, how to get these files into unigine. Do you have some ideas for workaround?
Hi Jirka,
Right now there is no other solution or workaround.
We hope that fix will be trivial and you can rebuild FBX plugin from sources on your side with a patch. However, we are still debugging and if issue is more serious the only option left is to wait until 2.8 SDK update, sorry.
On our side we are probably able to change version of fbx, so if there is any preferred version...
Hi Jirka,
The issue is on our side. Please, find the void FbxImporter::process_animations(fbx::FbxNode *fbx_node) method in source/plugins/Import/FbxImporter/FbxImporter.cpp and replace it with the following implementation:
	if ((flags & IMPORT_ANIMATIONS) == 0)
		return;
	using namespace fbx;
	FbxNodeAttribute *attribute = fbx_node->GetNodeAttribute();
	if (attribute && attribute->GetAttributeType() == FbxNodeAttribute::eSkeleton)
		FbxProperty property = fbx_node->GetFirstProperty();
		while (property.IsValid())
			for (auto &it : fbx_animations_layers)
				for (AnimationData &data : it.data)
					if (property.GetCurveNode(data.layer))
						if(!data.nodes.contains(fbx_node))
							data.nodes.append(fbx_node);
			property = fbx_node->GetNextProperty(property);
	int num_children = fbx_node->GetChildCount();
	for (int i = 0; i < num_children; ++i)
		process_animations(fbx_node->GetChild(i));
After that you need to rebuild a plugin on your side as described in that article: https://developer.unigine.com/en/docs/2.7.2/code/cpp/plugins/fbximporter/
Thanks for quick fix, we will try and let you know.
it's help and now it import right number of bones.
Thanks
Honya
Edited by honya
  • silent changed the title to [SOLVED] Import animation without mesh triple bones from fbx
