edit property in component system
why new  property  created auto  in componentsystem folder  after build project?
image.thumb.png.ad349c0cd4a420b60f48a4dd13fb654a.pngimage.thumb.png.af493a87ecd42c98a87a7894b55b84be.png
After editing again my properties, running the project will not change the properties in the componentsystem folder.
Is it okay if I do not mind the componentsystem folder?
Edited by dongju.jeong
all properties specified in the code will be created in this folder after the application starts.
I assume you changed some parameters via code and previously created *.prop files weren't changed. Am I right? If so, it's also supposed to be like that. Component system is still developing and this behavior is just a minor flaw. We already implemented new solution that will allow you to rewrite properties on the fly.
What can you do now:
  • delete created properties
  • edit your code (add some parameters for properties, change values etc)
  • run application
  • then check folder and your new properties
Briefly, if you want to manage properties parameters in the component system (by this I mean deleting, adding new or changing values) you'll have to delete old *.prop files and run your app again.
By the way, if you have more questions on the component system you can ask them in one forum thread.
Thank you!
