[SOLVED] create node by programming
Unigine componentsystem can has a node type parameter in the property.
Like Unity, is there a way to take a prefab in a script as a GameObject variable(Node) and create an object in the scene with the Instantiate () function?
The point is that Unity uses a prefab.
Is there a way to place an object in the scene with a function like instantiate () using something like Unity's prefab?
Could you please be more specific, what task you're trying to solve?
Do you want to clone a node with assigned property? Or you need to create a node in the world from code?
Thank you.
need to create a node in the world from code at runtime.
In the component system, I thought that I can create a node in the world with the code using the property node type parameter.
However, a node reference  can not assigned to the node type parameter.
If the unigine's node reference is equal to the unity's prefab,
I want to assign object information such as node reference(prefab) to a  parameter instead of assigning a node that already exist in world.
and then,
I want create new node in the world using that parameter with code.
Edited by dongju.jeong
Hi dongju.jeong,
If I got you right, you have a nodereference in a *.node file, and want to assign it to a property parameter, to create a node at run time via code.
In this case, you can add a "file" parameter to your property with a link to your *.node file (containing you nodereference), and then create a nodereference node at run time via code like this:
NodeReferencePtr nodeRef = NodeReference::create(node_file);// node_file is to be taken from the corresponding property parameter
These two articles may be useful:
Hope this helps!
Thank you!
  • silent changed the title to [SOLVED] create node by programming
