Dynamic Cubemap backing flickering
We r using Environment Probe for dynamic reflections in basically standard settings.
In some angles, situations I recognize, that the cubemap is flickering, caused by the rendering.
This is visible in objects at certain angles.
It is very obvious by rendering 1 Face/frame and at 6 faces/frame quicker flickering.
It does nearly disappear by deactivating TAA!
It is getting less visible, the higher the resolution of the cubamap is, but it doesnt disappear.
Is this a known issue?
Thx. Werner
Hi Werner,
Are you currently using SLI? SLI doesn't work well with dynamic reflectios. If you are using single GPUs build - could you please send us a small test scene for reproduction?
Hey. So I am narrowing it down a bit.
The issue is more a parallax surface. This surface is causing the main flickering in the cubemap together with the TAA.
And in detail, it is the NOISE parameter in the parallax setting (Material). Turning the noise to 0, then the flickering stops even using TAA.
So that might be reproducable I guess.
Thx.
Werner
Hello werner,
Can you please provide some video capture of flickering you are experiencing? Do you get flickering on parallax surface, or in reflection of parallax surface, or the whole cubemap itself flickers? Flickering of some pixels can be expected with TAA on low resolutions, you can experience it even without dynamic probe.
Thanks
need a possibility to send it.
The video is 200 MB
OKAY. I use the ftp upload..... Thx
Hello werner,
Unfortunately this is expected behavior with such setup. Noised texture with low resolution causes TAA flickering. It's doesn't relate to reflections or probes, it's just how TAA works. The best way to reduce flickering is to use higher resolution of dynamic reflection
Sorry for the inconvenience caused
okay. Thank you for taking a look.
Werner
