Animation for Decals in Tracker
It seems, that the tracker doesnt support Decals to be animated!
Is that true?
Need that .
thx.
Werner
Animating a parameter doesnt work.
Hi Werner,
Do you want to animate Radius / FOV / Aspect / ZNear parameters of Decal? Or something else?
As far as I can see these parameters are not exposed to tracker. You can manually extend data\core\systems\tracker\parameters\node.parameters to add required options. For example, for ZNear it will look something like that:
	<parameter type="node.decal.proj.ZNear" track="float" object="DecalProj">
		<set>OBJECT.setZNear(VALUE);</set>
		<get>VALUE = OBJECT.getZNear();</get>
	</parameter>
