mahasan Posted November 14, 2018 Posted November 14, 2018 hi we use syncker with 3 display that defined in diplay.sync file when we use (Unigine::getPlayerMouseDirection(p0,p1) in <core/scripts/utils.h> library) the returned direction is not match with the real mouse direction ; why? my example code is here example code_test:: Node mousePointer; int udp_port = 8890; int tcp_port = 8891; int tcp_ping_port = 8892; string Broadcast_address = "127.0.0.255"; SynckerInterface syncker; MasterInterface master; SlaveInterface slave; int init() { if(engine.syncker.getArgIsMaster()) { master = engine.syncker.initMaster(Broadcast_address, udp_port, tcp_port, tcp_ping_port, SYNCKER_COMPRESS_QUALITY_HIGH); syncker = engine.syncker.getSyncker(); syncker.setDebug(1, 10, 10, GUI_ALIGN_BOTTOM | GUI_ALIGN_RIGHT); } else { slave = engine.syncker.initSlave("slaveName", udp_port, tcp_port, tcp_ping_port, SYNCKER_COMPRESS_QUALITY_HIGH); syncker = engine.syncker.getSyncker(); syncker.setDebug(1, 10, 10, GUI_ALIGN_BOTTOM | GUI_ALIGN_RIGHT); } mousePointer = new NodeReference("Sphere.node"); Player player = new PlayerSpectator(); player.setPosition(Vec3(0.0f,-3.401f,1.5f)); player.setDirection(Vec3(0.0f,1.0f,-0.4f)); player.setControlled(0); engine.game.setPlayer(player); return 1; } int update() { Vec3 p0,p1; Unigine::getPlayerMouseDirection(p0,p1); mousePointer.setDirection(vec3(normalize(p1-p0))); mousePointer.setPosition(p0 + vec3(normalize(p1-p0))); return 1; }
morbid Posted November 14, 2018 Posted November 14, 2018 Hello Mahasan, as we mentioned earlier, getPlayerMouseDirection method doesn't work with multiscreen setups. However, this task is achievable, but only with C++ API. You can modify syncker plugin source code or write your own plugin that will catch screen modifications made by syncker. Thank you! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
