WidgetFlash incorrect blending of transparent pixels
We use sequence of png-files for realize animated cursor (not gui-cursor, simple cross-cursor), we use WidgetFlash, that load swf, that contains set of frames with transparency. Result is:
We see, Unigine blend transparency pixels with black.
Correct behavior: Unigine must blend pixels under widget (screen pixels).
  • 2 years later...
It would be very helpful if you can send us a simple test scene.
Hello vadim.sergeev,
I'm afraid, it's a problem with alpha channel compatibility between .swf format and Unigine.
This issue takes place only for images pasted into flash. Other transparent objects from .swf file are displayed correctly.
We've passed this issue to our developers and we'll inform you in case of any updates.
