Tooltips in VR Template
Hi!
I am trying to update Superposition's ObjTooltip to work inside the VR Template. Before doing so, I also have to make some changes to the Tooltips.h /Tooltips.cpp, but I am stuck at one point.
Here is the code I have slightly changed:
#pragma once
#include <UnigineNodes.h>
#include <UnigineVector.h>
#include <UnigineMap.h>
#include "ObjTooltip.h"
#include "../Players/VRPlayer.h"
class Tooltips
	static Tooltips& get()
		static Tooltips instance;
		return instance;
	static void hide(const char * event_name);
	void init(const Map<int, Vector<VRInteractable*>> *objs);
	void update();
	void setEnabled(int enabled, int immediately = 0);
	int isEnabled();
	void setPlayer(VRPlayer* player);
	vec3 getHeadPos(); // for PC / VR
	vec3 getHeadDir();
	Tooltips() {}
	~Tooltips() {}
	Tooltips(Tooltips const&) = delete;
	Tooltips& operator= (Tooltips const&) = delete;
	int is_enabled = 1;
	Vector<const char*> used_events; // activated events
	Vector<ObjTooltip*> tooltips;	// all tooltips in world
	// head position
	vec3 head_pos;
	vec3 head_dir;
	VRPlayer* player;
I'm getting errors with the constructor/destructor:
Tooltips() {}
    ~Tooltips() {}    (no apropriate constructor available)
And at
Vector<ObjTooltip*> tooltips; (undeclared Identifier - but in the api it gets highlighted as if it were right)
Could you please help me on it?
Hi Piotr,
Superposition logic was made before component system even existed, so you can't simply copy-paste code from one to another and hope that it would work. Right now we are in the middle of the release update and will be able to take a closer look later, sorry.
I will add task for the future releases so we will add stylized tooltips into VR template (already based on the component system).
Hi Silent,
I started learning programming recently and still can not understand many concepts in the code, I thought maybe it would not be hard to convert it so that it can be used with VR Template and the Component System, similiar to converting some Superposition's Objs.
Thanks, that would be great!:)
