zanpei Posted May 24, 2011 Posted May 24, 2011 if bind a child node to a parent node, and the parent node setEnable(0), while the child node setParent to another parent node(have setEnable(1)), the child node will not be seen. here is some code NodeDummy mNodeDummy ; /// set child node to another parent node void callback_redirector() { /// another parent node Node testMesh = engine.editor.getNodeByName( "testMesh" ) ; mNodeDummy.setEnabled(1) ;/// this fuction is not worked mNodeDummy.setParent(testMesh) ; } void init() { /// create button and callback function(set child node to another parent node) Gui gui = engine.getGui() ; WidgetButton button = new WidgetButton(gui,"setParent"); WidgetWindow window = new WidgetWindow(gui,"Window"); engine.gui.addChild(window, GUI_ALIGN_CENTER); window.addChild(button,GUI_ALIGN_CENTER); button.setCallback(GUI_CLICKED,"callback_redirector"); /// create particle ObjectParticles mObjectParticles = new ObjectParticles(); mObjectParticles.setName("NewParticles") ; mObjectParticles.setEnabled(1) ; mObjectParticles.setEmitterEnabled(1) ; mObjectParticles.setSpawnRate(100) ; mObjectParticles.setParticlesType(OBJECT_PARTICLES_TYPE_LENGTH) ; mObjectParticles.setEmitterType(OBJECT_PARTICLES_EMITTER_SHIFT) ; mObjectParticles.setVelocity(1,0) ; mObjectParticles.setRadius(0.1,0) ; mObjectParticles.setMaterial( "particles_base", 0 ) ; /// create dummy node mNodeDummy = new NodeDummy() ; mNodeDummy.setEnabled(1) ; mNodeDummy.setName("NewNodeDummy") ; mObjectParticles.setParent(mNodeDummy) ; /// parent node Node testBox = engine.editor.getNodeByName( "testBox" ) ; mNodeDummy.setParent(testBox) ; /// set parent node does not enable testBox.setEnabled(0) ; }
ulf.schroeter Posted May 24, 2011 Posted May 24, 2011 the child node will not be seen. What do you expect to see ? Your immediate child node is a NodeDummy, which itself is always invisible. Your ObjectParticles child of child has a SHIFT emitter, so particles will only be spawned/visible if you move your node hierachy. Is this the case ?
zanpei Posted May 25, 2011 Author Posted May 25, 2011 What do you expect to see ? Your immediate child node is a NodeDummy, which itself is always invisible. Your ObjectParticles child of child has a SHIFT emitter, so particles will only be spawned/visible if you move your node hierachy. Is this the case ? NodeDummy child move in update function, if you suspected, you will set the emitter type of ObjectParticles child to point, or set ObjectParticle to target parent node immediately.
zanpei Posted May 25, 2011 Author Posted May 25, 2011 and... set child node to another parent node, that is executived immediately, will not happend that case.So you will better create a callback function to set child node to another parent node, and click the button.
zanpei Posted May 26, 2011 Author Posted May 26, 2011 That's an emergency, I Need to set Particle between several parents, and the parent will be setEnable(0) sometimes. How to solve this question.Please answer me.
ulf.schroeter Posted May 26, 2011 Posted May 26, 2011 Provide smallest possible working test case (zipped *.cpp,*.world and required resources e.g. textures) for reproduction of problem. Otherwise in most cases it's hard for others to provide help just based on problem description.
zanpei Posted May 26, 2011 Author Posted May 26, 2011 Provide smallest possible working test case (zipped *.cpp,*.world and required resources e.g. textures) for repoduction of problem. Otherwise in most cases it's hard for others to provide help just based on problem description. here is a test case test.rar
ulf.schroeter Posted May 26, 2011 Posted May 26, 2011 Good test-case ! Quick-fix is to call setEnabled() AFTER setParent() on particle system. .... void callback_setParent() { Node testBox1 = engine.editor.getNodeByName( "testBox1" ) ; Node testParticle = engine.editor.getNodeByName( "testParticle" ) ; testParticle.setParent(testBox1) ; testParticle.setEnabled(1) ; } .... This will enable the particle system attached on the new parent. Still there remains a problem, as re-enabling of particle system will also show 'old' emitted particles on previous parent until end of their lift time. I assume that this is not what you want. Unfortunately currently there seems to be no way of clearing already emitted particles. A work-around could be to clone the particle system instead on re-assignment .... void callback_setParent() { Node testBox1 = engine.editor.getNodeByName( "testBox1" ) ; Node testParticle = engine.editor.getNodeByName( "testParticle" ) ; Node newParticle = testParticle.clone(); engine.editor.addNode( newParticle ); engine.editor.removeNode( testParticle ); newParticle.setParent(testBox1) ; newParticle.setEnabled(1) ; }
zanpei Posted May 27, 2011 Author Posted May 27, 2011 Good test-case ! Quick-fix is to call setEnabled() AFTER setParent() on particle system. Great!! It worked. This will enable the particle system attached on the new parent. Still there remains a problem, as re-enabling of particle system will also show 'old' emitted particles on previous parent until end of their lift time. I assume that this is not what you want. Unfortunately currently there seems to be no way of clearing already emitted particles. A work-around could be to clone the particle system instead on re-assignment I have modified the engine code(add clear function), so the particle emitter can clear the particles
ulf.schroeter Posted May 27, 2011 Posted May 27, 2011 I have modified the engine code(add clear function), so the particle emitter can clear the particles yep, this should be also done in regular UNIGINE code base.
