philip.li Posted December 19, 2018 Posted December 19, 2018 (edited) with unigine 2.7.1 qt frame after set the D3d11AppQt as sub widget of other widget (the crash bug will not occure in center widget),and start the engine , unigine will get crash over here. after debuging ,find that there was called QApplication::processevent when in setVideoMode function in AppQt when an engine object initialization, the processevent will call the timerEvent. however ,in that time, engine object just do not finish it's initialization, then do the update will cause crash. below is my resolution to fix that. Edited December 19, 2018 by philip.li
morbid Posted December 20, 2018 Posted December 20, 2018 Thank you Philip, as I understand this solution works for you, right? I'll forward this to our dev team. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
