[SOLVED] getParameterPtr is not nullptr when access id that not exist
from docs:
Quote
Ptr<PropertyParameter> getParameterPtr( int id )
Returns a property parameter by its ID.
Arguments
  • int id - Property parameter ID.
Return value
Property parameter smart pointer, if it exists; otherwise, nullptr.
As getNumParameters function deprecated, and i want to iterate through all parameters of my property, i go as:
for (int i = 0; property->getParameterPtr(i); i++) {
when i reaches 15 if logs into console:
 Property::getParameterPtr(): can't get parameter with id 15 in property "xxx_xxx"
and it is not nullptr, as it said in docs.
How can i handle that?
UPD: found way to get count of parameters through getNumChildren() at root parameter, but question about nullptr still actual.
Edited by qwert_e
Hi qwert_e,
Yes, there is a mistake. getParameterPtr() never returns nullptr. It always returns a PropertyParameter object, but the isExist() method may return 0.
And, you can't iterate through all of your parameters by one loop. Only through recursive function:
PropertyParameterPtr root_parameter = property->getParameterPtr();
std::function<void(const PropertyParameterPtr &)> recursive_func = [&, this](const PropertyParameterPtr &p)
	for (int i = 0; i < p->getNumChildren(); i++)
		PropertyParameterPtr child = p->getChild(i);
		// do something...
		recursive_func(child);
recursive_func(root_parameter);
Best regards,
Alexander
  • Like 2
I think this code sample should definitively be in the doc :)
Hi Amerio,
The mistake will be fixed and code samples will be added shortly. We're sorry for the inconvenience caused!
Thank you!
  • silent changed the title to [SOLVED] getParameterPtr is not nullptr when access id that not exist
