Guest shane.ploenges Posted May 30, 2011 Posted May 30, 2011 Hi, we have the following problem while exporting node files from 3ds max and then opening them in the editor: After opening the node file in the editor, all of the objects have lost the names they had in 3ds max, they are now all called ObjectMesh 1, 2,3,4, etc and so on.. this of course makes it very difficult to find a particular object in the scene when needed. Is there access to the Maxscript source code so that we can modify the exporter to export correct mesh names from 3ds max? or is there an easier way? Thanks In Advance.
ulf.schroeter Posted May 30, 2011 Posted May 30, 2011 Is there access to the Maxscript source code so that we can modify the exporter to export correct mesh names from 3ds max? or is there an easier way? You have to modify installed UNIGINE 3DSmax export script UniginExport.ms export script located in <your 3DSMax root>\Scripts\Startup folder. Maybe UNIGINE is willing to include it into SDK. UnigineExport.ms lines 380-420 ..... -- single mesh export if single then ( select nodes exportFile (path + "/meshes/" + name + ".mesh") #noprompt selectedonly:true format "\t<node type=\"ObjectMesh\" name=\"%\">\n" (name) to:file // ADDED NAME ATTRIBUTE format "\t\t<mesh>%</mesh>\n" (path_prefix + "meshes/" + name + ".mesh") to:file for node in nodes do ( export_surface "\t\t" node node.material mat_prefix file if findItem materials node.material == 0 then append materials node.material ) format "\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t</node>\n" to:file ) -- multiple mesh export else ( format "\t<node type=\"ObjectDummy\">\n" to:file for node in nodes do ( select node exportFile (path + "/meshes/" + node.name + ".mesh") #noprompt selectedonly:true format "\t\t<node type=\"ObjectMesh\" name=\"%\">\n" (node.name) to:file // ADDED NAME ATTRIBUTE format "\t\t\t<mesh>%</mesh>\n" (path_prefix + "meshes/" + node.name + ".mesh") to:file export_surface "\t\t\t" node node.material mat_prefix file format "\t\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t\t</node>\n" to:file if findItem materials node.material == 0 then append materials node.material ) format "\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t</node>\n" to:file )
ulf.schroeter Posted May 31, 2011 Posted May 31, 2011 Included required 3DSMax script modifications for name output into previous code excerpt.
Guest shane.ploenges Posted June 9, 2011 Posted June 9, 2011 Thanks very much, this worked great. Our 3ds max scripter here also added the function to sort the list alphabetically.
ulf.schroeter Posted June 9, 2011 Posted June 9, 2011 Our 3ds max scripter here also added the function to sort the list alphabetically. Than maybe you could post this code snippet, as this might be useful for others too.
Guest shane.ploenges Posted July 1, 2011 Posted July 1, 2011 Than maybe you could post this code snippet, as this might be useful for others too. Sorry it took so long, but here you go - this has made exporting large scenes much better to navigate for us here, sorry for posting the whole scriopt and not just the changes - but i am unsure what our scripter actually changed. /* Copyright (C) 2005-2011, Unigine Corp. All rights reserved. * * File: UnigineExport.ms * Desc: Unigine export plugin for 3D Studio Max * Version: 1.13 * Author: Alexander Zaprjagaev <frustum@unigine.com> * * This file is part of the Unigine engine (http://unigine.com/). * * Your use and or redistribution of this software in source and / or * binary form, with or without modification, is subject to: (i) your * ongoing acceptance of and compliance with the terms and conditions of * the Unigine License Agreement; and (ii) your inclusion of this notice * in any version of this software that you use or redistribute. * A copy of the Unigine License Agreement is available by contacting * Unigine Corp. at http://unigine.com/ */ /******************************************************************************\ * * other stuff * \******************************************************************************/ fn uppercase instring = ( local upper, lower, outstring upper="ABCDEFGHIJKLMNOPQRSTUVWXYZ" lower="abcdefghijklmnopqrstuvwxyz" outstring=copy instring for i=1 to outstring.count do ( j=findString lower outstring[i] if (j != undefined) do outstring[i]=upper[j] ) outstring ) /******************************************************************************\ * * Settings * \******************************************************************************/ /* */ fn set_settings name value = ( setINISetting (getDir #plugcfg + "\\UnigineExport.ini") "Unigine" name (value as string) ) fn get_settings name default = ( local value = getINISetting (getDir #plugcfg + "\\UnigineExport.ini") "Unigine" name if value == "" then return default return value ) /******************************************************************************\ * * Meshes * \******************************************************************************/ /* */ fn export_mesh type = ( -- select file local name = undefined if type == ".mesh" then name = getSaveFileName caption:"Select Mesh file" filename:(get_settings "export_mesh" "") types:"Unigine static mesh (*.mesh)|*.mesh" historyCategory:"Unigine" if type == ".smesh" then name = getSaveFileName caption:"Select MeshSkinned file" filename:(get_settings "export_smesh" "") types:"Unigine skinned mesh (*.smesh)|*.smesh" historyCategory:"Unigine" if type == ".sanim" then name = getSaveFileName caption:"Select MeshSkinned animation file" filename:(get_settings "export_sanim" "") types:"Unigine animation frames (*.sanim)|*.sanim" historyCategory:"Unigine" if name == undefined then return false if type == ".mesh" then set_settings "export_mesh" name if type == ".smesh" then set_settings "export_smesh" name if type == ".sanim" then set_settings "export_sanim" name -- check extension if getFilenameType name != type then name += type -- select nodes local nodes = #() if selection.count != 0 then ( for node in selection do ( if node.isHidden == true then continue append nodes node ) ) else ( for node in rootnode.children do ( if node.isHidden == true then continue append nodes node ) ) -- save selection local old_selection = selection as array -- export nodes select nodes exportFile name selectedonly:true -- restore selection select old_selection ) /* */ fn export_multi_mesh = ( -- select target directory local dir = getSavePath caption:"Select target directory" initialDir:(get_settings "export_multi_mesh" "") historyCategory:"Unigine" if dir == undefined then return false set_settings "export_multi_mesh" dir -- select nodes local nodes = #() if selection.count != 0 then ( for node in selection do ( if node.isHidden == true then continue append nodes node ) ) else ( for node in rootnode.children do ( if node.isHidden == true then continue append nodes node ) ) -- save selection local old_selection = selection as array -- export nodes for node in nodes do ( select node local name = dir + "/" + node.name + ".mesh" exportFile name #noprompt selectedonly:true ) -- restore selection select old_selection ) /* */ fn import_mesh type = ( -- select file local name = undefined if type == ".mesh" then name = getOpenFileName caption:"Select Mesh file" filename:(get_settings "import_mesh" "") types:"Mesh (*.mesh)|*.mesh" historyCategory:"Unigine" if type == ".smesh" then name = getOpenFileName caption:"Select MeshSkinned file" filename:(get_settings "import_smesh" "") types:"MeshSkinned (*.smesh)|*.smesh" historyCategory:"Unigine" if type == ".sanim" then name = getOpenFileName caption:"Select MeshSkinned animation file" filename:(get_settings "import_sanim" "") types:"MeshSkinned animation (*.sanim)|*.sanim" historyCategory:"Unigine" if name == undefined then return false if type == ".mesh" then set_settings "import_mesh" name if type == ".smesh" then set_settings "import_smesh" name if type == ".sanim" then set_settings "import_sanim" name -- import file importFile name ) /******************************************************************************\ * * Spline export * \******************************************************************************/ /* */ fn export_spline = ( -- check selection if selection.count == 0 then ( MessageBox "Selection is null" title:"Export error" return false ) -- export splines for node in selection do ( local name = getSaveFileName caption:"Select spline file" filename:(node.name + ".spline") types:"Spline (*.spline)" historyCategory:"Unigine" if name == undefined then return false exportFile name selectedonly:true ) ) /* */ fn export_camera = ( -- check selection if selection.count == 0 then ( MessageBox "Selection is null" title:"Export error" return false ) -- export cameras for node in selection do ( if classof node != FreeCamera and classof node != TargetCamera then continue local name = getSaveFileName caption:"Select camera file" filename:(node.name + ".txt") types:"Txt (*.txt)" historyCategory:"Unigine" if name == undefined then return false local file = openFile name mode:"wb" if file == undefined then ( MessageBox "Can't create file" title:"Export error" return false ) local current = currenttime local start = animationrange.start local end = animationrange.end local type = node.fovType node.fovType = 2 format "%\n" (((end - start) as integer) / TicksPerFrame) to:file for time = start to end do ( slidertime = time local xyz = node.transform.position local rot = node.transform.rotation format "% % % " xyz.x xyz.y xyz.z to:file format "% % % % " rot.x rot.y rot.z rot.w to:file format "%\n" node.curFOV to:file ) node.fovType = type slidertime = current close file ) ) /******************************************************************************\ * * Node export * \******************************************************************************/ /* */ rollout node_window "Unigine node exporter" width:320 height:180 ( checkbox single_cb "Single mesh" pos:[10,10] checked:true checkbox selected_cb "Selection only" pos:[10,32] checked:false checkbox base_cb "Base material" pos:[10,54] checked:false editText base_et "" pos:[100,54] width:200 readonly:true text:"mesh_base" checkbox mat_prefix_cb "Material prefix" pos:[10,76] checked:false editText mat_prefix_et "" pos:[100,76] width:200 readonly:true text:"" checkbox path_prefix_cb "Path prefix" pos:[10,98] checked:false editText path_prefix_et "" pos:[100,98] width:200 readonly:true text:"" button ok_b "Ok" pos:[130,140] width:80 height:24 button cancel_b "Cancel" pos:[220,140] width:80 height:24 -- export material map fn export_map map type path prefix file = ( -- check map if map == undefined then return false if classof map != Bitmaptexture then return false -- find texture local old_name = mapPaths.getFullFilePath map.filename if old_name == "" then return false local new_name = path + "textures\\" + getFilenameFile old_name + ".dds" -- fix paths for i = 1 to old_name.count do ( if old_name[i] == "\\" then old_name[i] = "/" ) for i = 1 to new_name.count do ( if new_name[i] == "\\" then new_name[i] = "/" ) -- texture name format "\t\t<texture name=\"%\">%</texture>\n" type (prefix + "textures/" + getFilenameFile old_name + ".dds") to:file -- compress texture local ret = undefined local command = "imagedds_x86.exe" if type == "diffuse" then ret = DOSCommand (command + " -m -c -o \"" + new_name + "\" \"" + old_name + "\"") if type == "normal" then ret = DOSCommand (command + " -m -n -a2 -o \"" + new_name + "\" \"" + old_name + "\"") if type == "specular" then ret = DOSCommand (command + " -m -c -o \"" + new_name + "\" \"" + old_name + "\"") if ret != undefined then ( -- check execution if ret != 0 then ( MessageBox ("Can't run \"" + command + "\" program") title:"Export error" ) -- check texture else ( local file = openFile new_name mode:"rb" if file == undefined then MessageBox ("Can't save \"" + new_name + "\" file") title:"Export error" else close file ) ) ) -- export material fn export_material mat path path_prefix file = ( -- two sided if mat.twoSided then ( format "\t\t<options two_sided=\"1\"/>\n" to:file ) -- alpha if mat.opacitymapenable then ( format "\t\t<options alpha_test=\"1\"/>\n" to:file ) -- anisotropy if mat.shaderType == 0 then ( format "\t\t<state name=\"light_omni\">2</state>\n" to:file format "\t\t<state name=\"light_cube\">2</state>\n" to:file format "\t\t<state name=\"light_proj\">2</state>\n" to:file format "\t\t<state name=\"light_world\">2</state>\n" to:file ) if mat.diffusemapenable then export_map mat.diffusemap "diffuse" path path_prefix file if mat.bumpmapenable then export_map mat.bumpmap "normal" path path_prefix file if mat.specularmapenable then export_map mat.specularmap "specular" path path_prefix file -- kill specular format "\t\t<parameter name=\"specular_scale\">0</parameter>\n" to:file format "\t\t<parameter name=\"specular_power\">1</parameter>\n" to:file ) -- export surface fn export_surface prefix node mat mat_prefix file = ( -- single surface if classof mat == StandardMaterial then ( format "%<surface name=\"%\" material=\"%\"/>\n" (prefix) (node.name) (mat_prefix + mat.name) to:file ) -- multiple surfaces else if classof mat == MultiMaterial then ( for i = 1 to mat.numsubs do ( local m = mat[i] if m != undefined and classof m == StandardMaterial then ( format "%<surface name=\"%\" material=\"%\"/>\n" (prefix) (node.name + "_" + m.name) (mat_prefix + mat.name + "_" + m.name) to:file ) ) ) ) -- export node fn export_node node = ( local single = single_cb.checked local selected = selected_cb.checked local base = base_cb.checked if base then base = base_et.text else base = "mesh_base" local mat_prefix = mat_prefix_cb.checked if mat_prefix then mat_prefix = mat_prefix_et.text else mat_prefix = "" local path_prefix = path_prefix_cb.checked if path_prefix then path_prefix = path_prefix_et.text else path_prefix = "" for i = 1 to path_prefix.count do ( if path_prefix[i] == "\\" then path_prefix[i] = "/" ) if path_prefix.count > 0 and path_prefix[path_prefix.count] != "/" then append path_prefix "/" local nodes = #() local materials = #() if selected then ( for node in selection do ( if node.material == undefined then continue if node.isHidden == true then continue append nodes node ) ) else ( for node in rootnode.children do ( if node.material == undefined then continue if node.isHidden == true then continue append nodes node ) ) -- sort nodes names_array = for ii in nodes collect (uppercase ii.name) sort names_array sorted_nodes = #() for ii = 1 to names_array.count do ( append sorted_nodes (getnodebyname names_array[ii]) ) nodes = sorted_nodes local path = getFilenamePath node local name = getFilenameFile node -- node file local file = openFile (path + "/" + name + ".node") mode:"wb" if file == undefined then return false format "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n" to:file format "<nodes version=\"1.0\">\n" to:file -- material library format "\t<materials>\n" to:file format "\t\t<library>%</library>\n" (path_prefix + name + ".mat") to:file format "\t</materials>\n" to:file -- export nodes makeDir (path + "/meshes") local old_selection = selection as array -- single mesh export if single then ( select nodes exportFile (path + "/meshes/" + name + ".mesh") #noprompt selectedonly:true node_name = name as string format "\t<node type=\"ObjectMesh\" name=\"%\">\n" node_name to:file format "\t\t<mesh>%</mesh>\n" (path_prefix + "meshes/" + name + ".mesh") to:file for node in nodes do ( export_surface "\t\t" node node.material mat_prefix file if findItem materials node.material == 0 then append materials node.material ) format "\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t</node>\n" to:file ) -- multiple mesh export else ( format "\t<node type=\"ObjectDummy\">\n" to:file for node in nodes do ( select node exportFile (path + "/meshes/" + node.name + ".mesh") #noprompt selectedonly:true node_name = node.name as string format "\t<node type=\"ObjectMesh\" name=\"%\">\n" node_name to:file format "\t\t\t<mesh>%</mesh>\n" (path_prefix + "meshes/" + node.name + ".mesh") to:file export_surface "\t\t\t" node node.material mat_prefix file format "\t\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t\t</node>\n" to:file if findItem materials node.material == 0 then append materials node.material ) format "\t\t<transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>\n" to:file format "\t</node>\n" to:file ) select old_selection format "</nodes>\n" to:file close file -- material file local file = openFile (path + name + ".mat") mode:"wb" if file == undefined then return false format "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n" to:file format "<materials version=\"1.0\">\n" to:file -- export materials makeDir (path + "/textures") -- base material if base != "mesh_base" then ( format "\t<material name=\"%\" parent=\"mesh_base\"/>\n" base to:file ) -- inherit materials for mat in materials do ( if classof mat == StandardMaterial then ( format "\t<material name=\"%\" parent=\"%\">\n" (mat_prefix + mat.name) base to:file export_material mat path path_prefix file format "\t</material>\n" to:file ) else if classof mat == MultiMaterial then ( for i = 1 to mat.numsubs do ( local m = mat[i] if m != undefined and classof m == StandardMaterial then ( format "\t<material name=\"%\" parent=\"%\">\n" (mat_prefix + mat.name + "_" + m.name) base to:file export_material m path path_prefix file format "\t</material>\n" to:file ) else ( format "\t<material name=\"%\" parent=\"%\"/>\n" (mat_prefix + mat.name + "_" + m.name) base to:file ) ) ) else ( format "\t<material name=\"%\" parent=\"%\"/>\n" (mat_prefix + mat.name) base to:file ) ) format "</materials>\n" to:file close file return true ) -- settings fn load_settings = ( single_cb.checked = ((get_settings "export_node_single_cb" "true") == "true") selected_cb.checked = ((get_settings "export_node_selection_cb" "false") == "true") base_cb.checked = ((get_settings "export_node_base_cb" "false") == "true") base_et.text = (get_settings "export_node_base_et" "mesh_base") base_et.readonly = not base_cb.checked mat_prefix_cb.checked = ((get_settings "export_node_mat_prefix_cb" "false") == "true") mat_prefix_et.text = (get_settings "export_node_mat_prefix_et" "") mat_prefix_et.readonly = not mat_prefix_cb.checked path_prefix_cb.checked = ((get_settings "export_node_path_prefix_cb" "false") == "true") path_prefix_et.text = (get_settings "export_node_path_prefix_et" "") path_prefix_et.readonly = not path_prefix_cb.checked ) fn save_settings = ( set_settings "export_node_single_cb" (single_cb.checked as string) set_settings "export_node_selection_cb" (selected_cb.checked as string) set_settings "export_node_base_cb" (base_cb.checked as string) set_settings "export_node_base_et" base_et.text set_settings "export_node_mat_prefix_cb" (mat_prefix_cb.checked as string) set_settings "export_node_mat_prefix_et" mat_prefix_et.text set_settings "export_node_path_prefix_cb" (path_prefix_cb.checked as string) set_settings "export_node_path_prefix_et" path_prefix_et.text ) -- events on node_window open do ( load_settings() ) on mat_prefix_cb changed state do ( mat_prefix_et.readonly = not state ) on path_prefix_cb changed state do ( path_prefix_et.readonly = not state ) on base_cb changed state do ( base_et.readonly = not state ) on ok_b pressed do ( local name = getSaveFileName caption:"Select node file" filename:(get_settings "export_node" "") types:"Node (*.node)" historyCategory:"Unigine" if name != undefined then ( if export_node name == false then ( MessageBox "Can't export node" title:"Export error" ) else ( set_settings "export_node" name save_settings() ) ) DestroyDialog node_window ) on cancel_b pressed do ( DestroyDialog node_window ) ) /******************************************************************************\ * * Menu * \******************************************************************************/ /* */ rollout about_window "About Unigine" width:220 height:80 ( label about_l "Unigine exporter for 3ds Max v1.10" pos:[16,16] button close_b "Close" pos:[120,40] width:80 height:24 on close_b pressed do ( DestroyDialog about_window ) ) /* */ macroScript export_mesh_action buttontext:"Mesh export" category:"Unigine" tooltip:"Export node to mesh" ( export_mesh ".mesh" ) macroScript export_smesh_action buttontext:"MeshSkinned export" category:"Unigine" tooltip:"Export node to mesh skinned" ( export_mesh ".smesh" ) macroScript export_sanim_action buttontext:"MeshSkinned animation export" category:"Unigine" tooltip:"Export node to mesh skinned animation" ( export_mesh ".sanim" ) macroScript export_multi_mesh_action buttontext:"Multi Mesh export" category:"Unigine" tooltip:"Export nodes to mesh files" ( export_multi_mesh() ) macroScript import_mesh_action buttontext:"Mesh import" category:"Unigine" tooltip:"Import node from mesh" ( import_mesh ".mesh" ) macroScript import_smesh_action buttontext:"MeshSkinned import" category:"Unigine" tooltip:"Import node from mesh skinned" ( import_mesh ".smesh" ) macroScript import_sanim_action buttontext:"MeshSkinned animation import" category:"Unigine" tooltip:"Import node from mesh skinned animation" ( import_mesh ".sanim" ) macroScript export_spline_action buttontext:"Spline export" category:"Unigine" tooltip:"Export spline" ( export_spline() ) macroScript export_camera_action buttontext:"Camera export" category:"Unigine" tooltip:"Export camera" ( export_camera() ) macroScript export_node_action buttontext:"Node export" category:"Unigine" tooltip:"Export node" ( createDialog node_window ) macroScript close_action buttontext:"Close" category:"Unigine" tooltip:"Export close" ( local menu = menuMan.findMenu "Unigine" if menu != undefined then ( menuMan.unRegisterMenu menu menuMan.updateMenuBar() ) ) macroScript about_action buttontext:"About" category:"Unigine" tooltip:"About Unigine" ( createDialog about_window ) /* */ fn init = ( local menu = menuMan.findMenu "Unigine" if menu != undefined then ( menuMan.unRegisterMenu menu menuMan.updateMenuBar() ) local main = menuMan.getMainMenuBar() local menu = menuMan.createMenu "Unigine" menu.addItem (menuMan.createActionItem "export_mesh_action" "Unigine") -1 menu.addItem (menuMan.createActionItem "export_smesh_action" "Unigine") -1 menu.addItem (menuMan.createActionItem "export_sanim_action" "Unigine") -1 menu.addItem (menuMan.createActionItem "export_multi_mesh_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "import_mesh_action" "Unigine") -1 menu.addItem (menuMan.createActionItem "import_smesh_action" "Unigine") -1 menu.addItem (menuMan.createActionItem "import_sanim_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "export_spline_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "export_camera_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "export_node_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "close_action" "Unigine") -1 menu.addItem (menuMan.createSeparatorItem()) -1 menu.addItem (menuMan.createActionItem "about_action" "Unigine") -1 local item = menuMan.createSubMenuItem "Unigine" menu local index = main.numItems() - 1 main.addItem item index menuMan.updateMenuBar() ) init()
