[SOLVED] CIGI & Node in mounted folder
I'm trying to access a node in a mounted folder.  What do I need to type for the path address in the ig_config.xml (I tried treating it as normal and it couldn't find the node)?  Is this possible? Thanks.
Hi Robert,
You need to specify paths relative to the data directory of your project. Do you have any errors in console regarding files being not found? Some more details about paths resolving you can also find in the following article: https://developer.unigine.com/en/docs/2.7.3/principles/filesystem/#paths
Can you show us your project structure (including *.umount contents and it's locations)?
Thanks for the link.  Followed the instructions and worked perfectly.  Sorry for the trouble.
  • silent changed the title to [SOLVED] CIGI & Node in mounted folder
