Coppel.Damien Posted March 11, 2019 Posted March 11, 2019 (edited) Hello, I want to generate georeferenced terrain in my world. I'm following the steps described in video tutorial "Georeferenced Terrain - UNIGINE Editor 2 Essentials". However, I am not able to add terrain files. I select them in the Landscape editor by clicking on "Add new", then in "Add Source" I point to the files I want to upload. Next I click on OK button. In the effect nothing happens, there are no files that have been added to i.e. height, as shown in the video tutorial and the button "Generate" is not active. Steps i take: Create new project - Load world into editor - Open Landscape editor form Tools - Select Georeferenced Mode - Right click on Height (Elevation) - Add new - Select wanted file - Click on OK button. Results : no files added, "generate" button inactive. Where am I making mistake ? Thank you Edited March 11, 2019 by Coppel.Damien
silent Posted March 11, 2019 Posted March 11, 2019 Hi Damien, More likely you need to load world first. Just open it via double-click in asset browser (*.world file). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Coppel.Damien Posted March 12, 2019 Author Posted March 12, 2019 Thank you for your reply. Unfortunately, it doesn't solve my problem, I was doing it from the beginning.
silent Posted March 12, 2019 Posted March 12, 2019 Hi Damien, That can be caused by wrong / unsupported heights format. Could you please send us your exact height files that are not loaded? You also should receive an error messages in console (Windows -> Console) when files were not loaded correctly. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted March 12, 2019 Posted March 12, 2019 Hello, The problem is shown in the console as 'GDALWrapper::Init(): can't load "libgdal.so" library' The .so exists in the folder sdks/sim_linux.../bin System is a Debian 8, 64 bits
morbid Posted March 12, 2019 Posted March 12, 2019 Hi @Amerio.Stephane, hi @Coppel.Damien! Can you check if some 3rd party libraries are missing? Just run ldd libgdal.so in the terminal. Usually, it can be solved by the installation of libpng. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted March 12, 2019 Posted March 12, 2019 We have the wrong version of gcc and cannot upgrade the system version: $ ldd libgdal.so ./libgdal.so: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./libgdal.so) ./libgdal.so: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./libgdal.so) linux-vdso.so.1 (0x00007ffe901e8000) libpng16.so.16 => not found libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9d8d3f0000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9d8d1d3000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9d8cfcf000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9d8ccc4000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9d8c9c3000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9d8c618000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9d8c402000) /lib64/ld-linux-x86-64.so.2 (0x00007f9d8e66f000) Does the delivered ligdal.so requires a different version from the other lib in the folder ? I can compile an Unigine app just fine and run the editor just fine apart from that.
morbid Posted March 12, 2019 Posted March 12, 2019 Stephane, can you be more specific? Is this libgdal.so from our SDK? Minspec for Unigine is gcc 4.7.2, by the wrong version you meant earlier gcc? Which debian is this? Looks like in 8.1 libstdc++ was updated and it has CXXABI_1.3.9 There's a chance that updating libpng will be enough. Could you give it a try? Thanks How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
morbid Posted March 12, 2019 Posted March 12, 2019 Stephane, I'm sorry, now it's clear. You can use the attached gdal on your system. We'll fix compilation error in the next release. gdal_patch.zip How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted March 12, 2019 Posted March 12, 2019 We have gcc (Debian 4.9.2-10) 4.9.2. With the patch copied over the sdk and in the project folder, it now works ! Thanks a lot ! Though an new error appeared in the console:' GDALWrapper::error_handler(): libNCSEcw.so.5.3.0: cannot open shared object file: No such file or directory'
morbid Posted March 12, 2019 Posted March 12, 2019 This file is included in the patch. I checked this patch with sim sdk before packing it. I suggest checking again these two libraries with ldd. Btw, have you installed libpng16? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted March 12, 2019 Posted March 12, 2019 Indeed, libNCSEcw.so.5.3.0 is present in the sdks folder (where I unzipped the patch), but when I created a new test project, it was not copied over along in the project folder (only the 5.4.0 is there). I now copied it manually, and it no longer complains. Thanks :) I did not install libpng16, as it wasn't complaining about it with your patch.
silent Posted March 12, 2019 Posted March 12, 2019 @Amerio.Stephane Do you plan to switch to the Debian Stretch (Debian 9)? GCC 4.9 is pretty old right now and we are thinking to move away from bugged GCC 4.7.2 to GCC 6.x+ (or maybe clang). And if we do this, Debian 9 will be our minspec for the engine to run. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted March 13, 2019 Posted March 13, 2019 We have no plan to update Debian anytime soon (due to compatibility with other tools). I understand that this version is rather outdated, but we are stuck with it for the moment :(
morbid Posted March 13, 2019 Posted March 13, 2019 18 hours ago, Amerio.Stephane said: Indeed, libNCSEcw.so.5.3.0 is present in the sdks folder (where I unzipped the patch), but when I created a new test project, it was not copied over along in the project folder (only the 5.4.0 is there) 1 SDK Browser copies predefined library (the newer one). On this PC you'll have to manually add libNCSEcw .so.5.3.0 into each project you create. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted April 19, 2020 Posted April 19, 2020 @Amerio.Stephane Are you still using this Debian 8? Any luck to Debian 9 migration in the nearest couple of months? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Amerio.Stephane Posted April 19, 2020 Posted April 19, 2020 11 hours ago, silent said: Any luck to Debian 9 migration in the nearest couple of months? Debian 8 is still the main OS we have to deal with for the next months (the other being Debian 6... "sigh"). Debian 9/10 is indeed the next platform we'll have to support, and some plans are being made, but things are moving slowly here (a LOT of simulations would need to be ported, and that is not easy.) I can't see us moving to D9 realistically this year. I guess you meant to warn us the very near future may be D9+ only? This is important for us to know about.
silent Posted April 19, 2020 Posted April 19, 2020 Just checking in, because Debian 8 LTS support ends this June and we probably would need to go further: https://wiki.debian.org/LTS We are still using Debian 8 for the Linux build system, in case of any changes I will surely let you know :) How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
