Component State parameter
When Test by  Hemu, I got "255" for component state value. (in ComponentPacket of  LandingGears, LightAircraftController......)
What does the value of this component state mean in general?
I read Cigi's document but I didn't understand it.image.png.ca7c4ea5ea3b02a38fbe1aec3353bcac.png
A component can work with State or with Data values. We're currently using Component-Specific Data. The state is some pre-defined value. For instance, landing gears can have two states: deployed and retracted.
Quote
The value in the selected field controls the value of a property as described here: https://developer.unigine.com/en/docs/2.7.3/ig/properties_setup
Are you experiencing some problems with this?
Thanks.
I understand. thank you.
Data1~6 parameter type can be only Basic data type(int,float...)???  can't be type such as vector?
Edited by dongju.jeong
yes, only basic data type. it`s defined in CIGI 3.3  (4-byte word)
if you want send vector - use {data1,data2,data3}.
state in ig_config.xml was written for example settings only.
You can write your custom components using state.
