custom logging system
Hi
Is there any way to redirect unigine logs to our own logging system? I need to create unified logging.
So, the ideal would be something like a registration log handler or functor.
        thank you  Aargh
Hello aargh,
May I ask you to elaborate on this? How do you see a final result? As a new log file where you can see all UNIGINE log messages and messages from your application?
Thanks.
Hi Morbid
Yes that is the target state. Our app is already using its log system, and it would be perfect if we could even connect unigine logging to it.
As I wrote above, something like redirecting logs would be ideal.
        aargh
Edited by aargh
Hi
Thanks, it works perfectly, only it can't catch messages from engine start to the interpreter's start.
If it was similar to a callback on the Log class....   ;-)
        aargh
On 5/27/2019 at 10:06 AM, morbid said:
Do you need this info as well?
Yes it would be useful
I've checked with the engine team. You can't get these messages (from engine start to the interpreter's start) with standard API. In theory, you can take them through stdout, but it will require some extra effort from your side.
Thanks.
Hi
Extra effort doesn't matter if there's a way to do it. Please add more details.
If I understand it correctly, it will be redirecting stdout to file or named pipe
        aargh
Hello aargh,
Yes, stdout can be redirected to file or pipe. There's nothing Unigine specific here. This snippet seems to be working for Windows:
#include <windows.h>
#include <io.h>
#include <functional>
#include <iostream>
#define STDOUT_FILENO 1
#define STDERR_FILENO 2
enum StdHandleToRedirect
	STDOUT, STDERR
class StdRedirect
	/// Assumes the specified handle is still assigned to the default FILENO (STDOUT_FILENO/STDERR_FILENO)
	/// TODO allow redirection in every case
	/// callback will run in a new thread and will be notified of any character input to
	/// the specified std handle
	StdRedirect(StdHandleToRedirect h, std::function<void(char)> callback): callback(callback)
		CreatePipe(&readablePipeEnd, &writablePipeEnd, 0, 0);
		SetStdHandle(h == STDOUT ? STD_OUTPUT_HANDLE : STD_ERROR_HANDLE, writablePipeEnd);
		// Redirect (TODO: ERROR CHECKING)
		int writablePipeEndFileStream = _open_osfhandle((long)writablePipeEnd, 0);
		FILE *writablePipeEndFile = NULL;
		writablePipeEndFile = _fdopen(writablePipeEndFileStream, "wt");
		_dup2(_fileno(writablePipeEndFile), h == STDOUT ? STDOUT_FILENO : STDERR_FILENO);
		CreateThread(0, 0, (LPTHREAD_START_ROUTINE)stdreader, this, 0, 0);
	// TODO implement destructor, cleanup, reset
	// DWORD (WINAPI *PTHREAD_START_ROUTINE)(LPVOID lpThreadParameter)
	static void WINAPI stdreader(StdRedirect *redirector)
		while (1)
			char c;
			DWORD read;
			::fflush(NULL); // force current stdout to become readable
			// TODO add error handling
			ReadFile(redirector->readablePipeEnd, (void *)& c, 1, &read, 0); // this blocks until input is available
			if (read == 1)
				redirector->callback(c);
	HANDLE readablePipeEnd, writablePipeEnd;
	const std::function<void(char)> callback;
Unigine::String buf;
std::function<void(char)> toOutputDebugString = [&](char x)
	buf.append(x);
StdRedirect so(STDOUT, toOutputDebugString);
StdRedirect se(STDERR, toOutputDebugString);
Hi
Thank you. This is fantastic reply.
                                                 aargh
