arzezniczak Posted July 1, 2019 Posted July 1, 2019 (edited) Hello, In AppWorldLogic::Init method I'm adding my command using Unigine::Console::get( )->addCommand (I've tried do the same but in AppEditorLogic::Init - same behaviour) If I run application through launch_debug.bat or launch_release.bat - command is available, I can use it, but if I run my app through launch_editor.bat and in editor console I'm trying to invoke my command I only get "Unknown command" error. How can I add command that will be available in editor console? PS. I'm creating complicated nodes hierarchy in runtime and I want to see If it's correct in "easy way" in editor "world node hierarchy" window. Edited July 1, 2019 by arzezniczak
morbid Posted July 1, 2019 Posted July 1, 2019 Hi. You're using C++ or C# I guess? If so, Editor wouldn't "see" any written logic. There are two workarounds: 1. Use UnigineScript. Add your console command in the project_name.usc file. This will work in the Editor. For instance: void console_action_callback() { log.message("first action! no arguments!\n"); } // a script function to be executed for 1 argument input void console_action_callback(string arg) { log.message("second action! the argument is: %s\n",arg); } int init() { // add a command engine.console.addCommand("console_action","my_command description","console_action_callback"); return 1; } 2. Save the node with saveNode and check it manually in the Editor: https://developer.unigine.com/en/docs/2.8/api/library/engine/class.world?rlang=cpp#saveNode_cstr_Node_int_int Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
arzezniczak Posted July 2, 2019 Author Posted July 2, 2019 Yes, I'm using C++ API. First I've tried second workaround - generally it works but it's a bit pain to iterate with this save/load method. Then I've tried the first one and I have a problem. I'm using some external dll during this node creation process. I have tried to pack everything into one function in namespace and export to script using Interpreter::addExternFunction, but Editor is complaining that name of my namespace is "unknown token". Any idea what I'm doing wrong here? C++ side: // main #ifdef _WIN32 int wmain(int argc, wchar_t *argv[]) #else int main(int argc, char *argv[]) #endif { Unigine::Interpreter::addExternLibrary( "ImportHelpers" ); Unigine::Interpreter::addExternFunction( "ImportHelpers.Import", Unigine::MakeExternFunction( &ImportHelpers::Import ) ); // init engine Unigine::EnginePtr engine(UNIGINE_VERSION, argc, argv); // UnigineLogic AppSystemLogic system_logic; AppWorldLogic world_logic; AppEditorLogic editor_logic; // enter main loop engine->main(&system_logic, &world_logic, &editor_logic); return 0; } // ImportHelpers.h namespace ImportHelpers { void Import( Unigine::String filePath ); } // ImportHelpers.cpp void ImportHelpers::Import( Unigine::String filePath ) { //importing file using external lib, creating Unigine nodes etc... } Unigine script: void my_import_callback(string arg) { ImportHelpers.Import(arg); // here interpreter complains about 'unknown token "ImportHelpers"' } int init() { // Write here code to be called on world initialization: initialize resources for your world scene during the world start. Player player = new PlayerSpectator(); player.setPosition(Vec3(0.0f,3.401f,1.5f)); player.setDirection(Vec3(0.0f,-1.0f,-0.4f)); engine.game.setPlayer(player); engine.console.addCommand("my_import","my_import desc","my_import_callback"); return 1; }
alexander Posted July 2, 2019 Posted July 2, 2019 Hi, I think you need to: 1) Create your own C++ plugin: https://developer.unigine.com/en/docs/2.8/code/cpp/plugin?rlang=cpp Put inside Plugin::init() function your Unigine::Console::get( )->addCommand(...) command. 2) Use command line argument to attach it to the Editor: -extern_plugin "MyPlugin" Best regards, Alexander 1
