davide445 Posted August 16, 2019 Posted August 16, 2019 (edited) For a couple of weeks I will need to work remotely on my PC using also Unigine. Want to ask if there are any experience in doing so, and if there are any best practice for best performances. Tested TeamViewer appear to be really laggy on 3d applications, testing NoMachine (NX technology) appear to be faster but so far I was not able to make him work in a repeatable way, just read about AnyDesk so not sure what can be the best solution. PC is dual boot Windows 10 and Linux but will use the Windows boot, will be accessed from my Windows 10 laptop. Edited August 16, 2019 by davide445
morbid Posted August 16, 2019 Posted August 16, 2019 Hello Davide, In general, connection quality depends only on the channel (the faster the connection the smoother remote desktop will work), but there'll be lags in any case (remember, you're doing it via network :)). For Windows — Windows connection it's better to use standard Remote Desktop application, experiment with the optimization settings for better result. My colleague also suggested https://www.remoteutilities.com/ if you need to work when the target Windows machine is already used by another person (like Team Viewer support session). Thanks. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
davide445 Posted August 16, 2019 Author Posted August 16, 2019 Thanks, I will test also Remote Desktop. Of course depends from the connection, that's why I was testing also NoMachine, supposed to work well also with very narrow bandwidth.I didn't need to work concurrently with others. The other best option is to bring the whole PC with me, just a logistic problem in finding the space for also this package...
demostenes Posted August 24, 2019 Posted August 24, 2019 You should try some technology made for streaming games. They are optimized for that. I would try something like this: https://moonlight-stream.org/
davide445 Posted August 25, 2019 Author Posted August 25, 2019 (edited) For the next two weeks I have solved the problem in a different way: will relocate with me the whole PC and monitor! But this suggestion will become useful later this year after changing the office where I work, so will check also that, thanks @demostenes. Edited August 25, 2019 by davide445
davide445 Posted November 22, 2019 Author Posted November 22, 2019 (edited) Just to signal I tested NoMachine for working with my PC situated in the office about 4km away, works fine. Also discovered applications such as TeamViewer and AnyDesk are not really suited for 3D usage since they seems not recognize the hold button command, recognizing only the single click. Suppose they are made for a different goal. Edited November 22, 2019 by davide445
