gary Posted August 23, 2019 Posted August 23, 2019 I'm experiencing consistent crashes on one project when I attempt to edit content. Initializing assets loads until 95% then hangs for 5 mins and crashes. Before these crashes started I did notice that the project crashed when I attempted to edit the world clutter trees. I've followed some of the fixes in other threads here but still no luck. All other projects open fine.
silent Posted August 23, 2019 Posted August 23, 2019 Hi Gary, Did you have chance to check the engine log file in <YourProject>/bin/log.html? Usually it contains some useful information about the overall project state (including errors and warnings). Could you please attach this log to this thread? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
gary Posted August 23, 2019 Author Posted August 23, 2019 Hi Silent I've attached the log files... log_0.html log_1.html
silent Posted August 23, 2019 Posted August 23, 2019 Hi Gary, It seems that you had imported couple of bad FBX files. Engine failed to load jpeg/png files that were associated with FBX. I would recommend to delete all files that marked as orange in log file and try to run Editor one more time. Could you please also send us these FBX files with all textures for investigation: tbd_pathbone_0.FBX C300Black_0.FBX If you are using version control system it's better to update to the last working revision. Maybe files were damaged after unexpected Editor shutdown, it's hard to say really. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
gary Posted August 26, 2019 Author Posted August 26, 2019 Thanks Silent that worked! I've attached those files plus another log file that's still showing a lot of orange. Gary. log.html tbd_pathbone_0.FBX C300Black_0.FBX BChrybl.jpg.meta C300Black_0.FBX
silent Posted August 27, 2019 Posted August 27, 2019 Hi Gary, You did send a .node files instead of FBX. But let's forget about it for a moment. Is there any chance that you manually edited data folder contents without using an Editor? In a log file, there are plenty of errors and warnings (broken material files, textures and so on), that I'm afraid will be hard or impossible to fix without reverting to the previous working revision. If you don't use the version control system it would mean that probably you will be required to rebuild a project from scratch (create a new project, add whole contents again). Could you please also upload your data directory to some file hosting and send me a link via PM? If there is a crash with trees clutter edit I would like to reproduce it first so our team would be able to fix it in the new releases. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
gary Posted February 14, 2020 Author Posted February 14, 2020 Hi Guys, I'm having a similar problem to this previous issue with Unigine not initializing. I'm trying to fix an old world from an old sdk but I think bringing it into the new sdk has created some problems. I've attached the log file. Can you see where the issue might be? Also I'd like to upgrade from the version I'm using 2.7.3.1 to 2.10.0.2 to use the new cleaning tool but I'm getting a warning saying all modifications of files and structures will be lost!? This sounds a little ominous. log.html
silent Posted February 14, 2020 Posted February 14, 2020 Hi Gary, In some cases it may occur that re-creating the scene from scratch would be much easier and faster. There are too many errors in your log, I doubt that you can migrate such project. Unfortunately, it's also not possible to understand from the attached log file why these errors occur at the first place. My initial though was that some bugged FBX files were imported, but it looks some other bad things are happens here (maybe some manual data folder editing without editor). We can take a look at your project if you will send us. Maybe it will give us a clue why it happens if we can see the whole picture, but chances are very low. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
gary Posted February 14, 2020 Author Posted February 14, 2020 Thanks Silent, I'll have a think about that. Unfortunately I can't send you the project.
morbid Posted February 14, 2020 Posted February 14, 2020 1 hour ago, gary said: Also I'd like to upgrade from the version I'm using 2.7.3.1 to 2.10.0.2 If you have time I suggest upgrading the project step by step (2.7.3.1 -> 2.8, 2.8 -> 2.9, etc.) And check every version. Cleaning the original 2.7.3.1 project form suspicious or malfunctioning assets is also a good idea (investigate all log errors before the upgrade). Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
gary Posted February 14, 2020 Author Posted February 14, 2020 Thanks Morbid, I'm giving that a go now...
