zhou.you Posted August 31, 2019 Posted August 31, 2019 VAPS, a precursor to VAPS XT, is designed for the development of dynamic interactive real-time graphical HMIs for complex applications, including the displays and controls found in the cockpit of an aircraft as well as in automobile instrumentation.
silent Posted September 2, 2019 Posted September 2, 2019 zhou.you There is not so many information available on this tool. However, if you already have an access to this library you probably can also check the documentation on it's API. If it has C / C++ API you can write a custom UNIGINE plugin that will render all the GUI on top of the UNIGINE window. There are couple of similar plugins already available: Noesis GUI: https://developer.unigine.com/forum/topic/4639-implementation-noesisgui-gui-sample/ CoherentGT: https://developer.unigine.com/forum/topic/4638-implementation-coherentgt-gui-sample/ You also can check a sample on custom plugin creation in SDK Browser: Samples -> C++ API -> Systems -> Plugins Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
