[SOLVED] Load render settings
I am trying to load render settings (file created by Save it from Settings window) as:
Render::get()->loadSettings("myfile.render");
and then I get message:
Xml::load(): can't open "" file
Render::loadSettings(): can't load "myfile.render" file
this file is located just in data folder.
I can load it by double click in editor or via lua.
Do you have any idea ?
Cheers
Edited by Klimczak.Jan
Hi Jan,
Could you please check if this file is present in engine virtual filesystem (console command: filesystem_list)? If there is no such file, you can manually reload filesystem via filesystem_reload command and file will appear in list.
  • silent changed the title to [SOLVED] Load render settings
