Render settings
Is it possible to load render settings (*.render files) from C++? from the console ?
Can ".render" files be only partially specified (for examples with only bloom settings). This would be usefull for loading different section settings without duplicating a lot of other settings.
Thank you.
Hi Stephane,
You can use Render::loadSettings method for that: https://developer.unigine.com/en/docs/2.9/api/library/rendering/class.render#loadSettings_cstr_int
Quote
Right now partial overrides are not implemented. I would create a feature request for that task in tracker (with low priority ATM).
Ok for C++. But not possible through a console command?
Can the render settings be specified in the startup cmd line? (sorry if I missed it in the doc)
