roberto.voxelfarm Posted October 1, 2019 Posted October 1, 2019 I try to recreate a shader like the sample on https://learnopengl.com/Advanced-OpenGL/Geometry-Shader on the sample is use a vertex point as geometry in. Using UUSL the GEOM_TYPE_IN. How I can put a POINT or a Vertex?, for now my two valid options are GEOM_TYPE_IN(LINE_IN) or GEOM_TYPE_IN(TRIANGLE_IN) I try parameters like VERTEX_IN, POINT_IN etc but all of then give me "error X3000: unrecognized identifier" VERTEX_IN or POINT_IN In fact if you do a search on all your documentation for GEOM_TYPE_IN shader definition don't appear nothing. The only reference to the LINI_IN or TRIANGLE_IN appear on the https://developer.unigine.com/en/docs/2.9/code/uusl/semantics?rlang=cpp under the "Geometry Shader Semantics#" section. This is the shader sample from the web site, were for each vertex IN emit 5 vertex OUT as triangle strip #version 330 core layout (points) in; layout (triangle_strip, max_vertices = 5) out; void build_house(vec4 position) { gl_Position = position + vec4(-0.2, -0.2, 0.0, 0.0); // 1:bottom-left EmitVertex(); gl_Position = position + vec4( 0.2, -0.2, 0.0, 0.0); // 2:bottom-right EmitVertex(); gl_Position = position + vec4(-0.2, 0.2, 0.0, 0.0); // 3:top-left EmitVertex(); gl_Position = position + vec4( 0.2, 0.2, 0.0, 0.0); // 4:top-right EmitVertex(); gl_Position = position + vec4( 0.0, 0.4, 0.0, 0.0); // 5:top EmitVertex(); EndPrimitive(); } void main() { build_house(gl_in[0].gl_Position); } /roberto
consta Posted October 2, 2019 Posted October 2, 2019 Hi roberto, Try this #include <core/shaders/common/common.h> STRUCT(GEOMETRY_OUT) INIT_POSITION END STRUCT(GEOMETRY_IN) INIT_POSITION END GEOM_COUNT_IN(1) GEOM_TYPE_IN(POINT_IN) GEOM_MAX_VERTICES(5) GEOM_TYPE_OUT(TRIANGLE_OUT) MAIN_GEOM_BEGIN(GEOMETRY_OUT, GEOMETRY_IN) OUT_POSITION = IN_GEOM_POSITION(0) + float4(-0.2, -0.2, 0.0, 0.0); EMIT_VERTEX; OUT_POSITION = IN_GEOM_POSITION(0) + float4( 0.2, -0.2, 0.0, 0.0); EMIT_VERTEX; OUT_POSITION = IN_GEOM_POSITION(0) + float4(-0.2, 0.2, 0.0, 0.0); EMIT_VERTEX; OUT_POSITION = IN_GEOM_POSITION(0) + float4( 0.2, 0.2, 0.0, 0.0); EMIT_VERTEX; OUT_POSITION = IN_GEOM_POSITION(0) + float4( 0.0, 0.4, 0.0, 0.0); EMIT_VERTEX; END_PRIMITIVE; END_GEOM You should also render vertex buffer with that mode that you declared as input in geometry shader. For example mesh dynamic in c++ code: mesh_dynamic->render(MeshDynamic::MODE_POINTS, 0); then in your shader: GEOM_COUNT_IN(1) GEOM_TYPE_IN(POINT_IN) Appropriate files attached. For easier understanding of error you can append EXPORT_SHADER(some_name) to the end of your shader to see your result code in GLSL or HLSL. Corresponding *.glsl or *.hlsl file will appear in data/ after each shaders recompilation. There are also built-in defines DIRECT3D11 and OPENGL. In shader you can write in native language: #ifdef OPENGL // GLSL code #elif DIRECT3D11 // HLSL code #endif AppWorldLogic.cpp AppWorldLogic.h ptcloud.basemat ptcloud.shader 1
roberto.voxelfarm Posted October 2, 2019 Author Posted October 2, 2019 Thank you Consta I appreciate this. I make a small modification for use with ObjectDynamic then I don't have to put callback. void AppWorldLogic::InitObjectDynamic03_4() { ObjectDynamicPtr omd = ObjectDynamic::create(ObjectDynamic::DYNAMIC_VERTEX); ObjectDynamic::Attribute cFormate[] = { { 0, ObjectDynamic::TYPE_FLOAT, 4 } }; omd->setVertexFormat(cFormate, 1); omd->setSurfaceMode(ObjectDynamic::MODE_POINTS, 0); omd->setMaterialNodeType(Node::OBJECT_DYNAMIC); omd->setVertexFormat(attributesPoint, 1); for (int i = 0; i < 3; i++) { vec4 vertex = vec4(i * 0.7, 0, 0, 1.0f); omd->addVertexFloat(0, vertex, 4); omd->addIndex(i); } omd->flushVertex(); omd->flushIndices(); MaterialPtr mat = Materials::get()->findMaterial("pthouse"); omd->setMaterial(mat, "*"); omd->setEnabled(1); } ptHouse.basemat <?xml version="1.0" encoding="utf-8"?> <base_material name="pthouse" editable="0" version="2.5.0.2"> <shader pass="deferred" deferred="1" defines="BASE_DEFERRED" node="object_dynamic" vertex="mat/ptcloud/ptHouse.shader" geometry="mat/ptcloud/ptHouse.shader" fragment="mat/ptcloud/ptHouse.shader"/> </base_material> And the shader without any change /Roberto
