Unigine SDK 2010-09-07
Recent changes
* Updated terrain system (see details below).
* TerrainEditor has been integrated into UnigineEditor and improved.
* Added new terrain samples.
* Added documentation on updated terrain system and its editor: "Principles of Operation / Objects / Terrain".
* Fixed some sound-related crashes.
* Added 'PostRefraction' flag into materials: transparent objects can be drawn after the refraction pass with this flag enabled.
* Thread-unsafe updates of objects have been moved to flush() stage.
* Added setViewDirection()/getViewDirection() methods to players.
* Renamed 'clipping' option of particles into 'culling' (don't forget to run utils/upgrade.py).
* Fixed green background at video playback start.
* Added function for setting of initial particle speed.
* Physics API function setFrozenable() was renamed into setFreezable().
* Time-based filtration of contacts in physics.
* Safe multithreaded collisions with terrain.
* More verbose warnings in Direct3D9/10/11.
* Fixed setting of Unicode window caption.
* Added support of texture atlas (4x4) for particles.
* Added blend() function into Image class.
* Completely removed clipmap support.
* Reduced memory consumption in UnigineScript.
* Improved swizzlers for variables in UnigineScript: now it's possible to set '1' and '0' values (e.g. foo.xy0 bar.01x).
* Even more performance boost in UnigineScript.
* WidgetGridBox now correctly handles all hidden child widgets.
* Full-screen mode isdows SDK 7.1 set to the primary output device now.
* Fixed array elements access in UnigineScript (array[2][2]).
* Added unicodeToUtf8() and utf8ToUnicode() functions into UnigineScript.
* Correct work with SN compiler for PS3.
* Inverted Y-axis of grass mask.
* New WorldClutter object for procedural placing nodes from a predefined set around the player according to the mask image.
* Added dot() function for quaternions in API.
* New 'EmitterBased' flag in particle systems (particles follow the emitter).
* Added _CELLOS_LV2 define into UnigineScript for PS3.
* More fine tuning parameters for grass culling.
* Added script for handling Euler angles (data/core/scripts/euler.h).
* Removed WorldTransform editor from UnigineScript.
* Added PhysicalTrigger node, which works the same way as WorldTrigger, but uses physical world data and can have any physical shape.
* 'contact' parameter was renamed into 'touch' in WorldTrigger.
* Access to shapes in player contacts.
* Support of arbitrary blur radius for DoF.
* Added physical ropes.
* ComboBox widget now fires corrert GUI_CLICKED callback.
* Added several rope samples.
* Added small 'tessellation' demo into SDK.
* Project files were upgraded to be compliant with Visual Studio 2010 Express.
* Added support of Windows SDK 7.1.
* Added a set of articles on physics into the reference manual: see "Principles of Operation / Physics" chapter.
Terrain changes
Main features of the renewed terrain:
* Built-in terrain editor
* Heightmap streaming
* Holes
* Texture splatting
* Optional triplanar texturing
* Automatic texture streaming
* The maximum size is 65536+1 x 65536+1
More details on terrain update can be found in the reference manual and in the corresponding forum thread: https://developer.unigine.com/forum/topic/11-terrain-update/
Download links
Source version:
http://unigine.com/transfer/src/Unigine-20100907-src.zip (ZIP archive)
http://unigine.com/transfer/src/UnigineSDK-source-2010-09-07.exe (Windows installer)
Binary version:
http://unigine.com/transfer/binary/Unigine-20100907-bin.zip (ZIP archive)
http://unigine.com/transfer/binary/UnigineSDK-binary-2010-09-07.exe (Windows installer)
Tools pack can be downloaded from "Downloads" section of the portal: https://developer.unigine.com/fileserver/download/UnigineTools-2010-09-07.exe
Next update of the SDK will be distributed exclusively via Unigine Developer Community.
You are welcome. BTW, we plan to get back to the monthly SDK update cycle.
Congratulations to the whole team, this is really a great UNIGINE release !
  • 2 weeks later...
Sorry guys, it seems that the next SDK update will take some more time (3-4 weeks more) since there are a lot of ongoing render improvements (new postprocesses like SSDO and motion blur, additional performance boost) and we can't release it until they are completed.
