davide445 Posted October 25, 2019 Posted October 25, 2019 (edited) Starting from 3dsmax project where the wood panels are vertical using an Unwrap UVW modifier to rotate 90° the UV and achieve this result Exported as fbx using Game settings and imported in Unigine, recreating the material using the base texture show an horizontal orientation Need I to change something else? Edited October 26, 2019 by davide445
werner.poetzelberger Posted October 25, 2019 Posted October 25, 2019 Are you using 3dsmax to export. As a guess, put an Editable Poly Modifier on top, then export it. Or collapse the stack (if you can do that for your project). b.w. 1
davide445 Posted October 25, 2019 Author Posted October 25, 2019 (edited) Thanks Werner I used an Unwrap UVW modifier on top of the Editable Mesh and used the UV Editor to rotate it. Trying Edit Poly modifier I didn't see any option to do so. Or you was meaning something else? Edited October 25, 2019 by davide445
werner.poetzelberger Posted October 25, 2019 Posted October 25, 2019 Add an Edit poly modifier on top of the Unwrap. Then export it. (sry for the kiddy drawing ;) 1
davide445 Posted October 25, 2019 Author Posted October 25, 2019 Werner it worked. The point is I really didn't understand why. I attach the 3dsmax file in 2019 format and the textures for Unigine, will be very helpful to know why just adding a modifier (that I didn't know before) not related to UV in fact solved the problem. The wall without any modifier show the wood vertical in max (correct), horizontal in Unigine (wrong). With just the UVW Unfold modifier and rotating 90° the UV the wood is horizontal in max (wrong), also horizontal in Unigine (wrong) With also the Edit Poly modifier result horizontal in max (wrong), but vertical in Unigine (correct) Really didn't get it. Basic_wall_2019.max
werner.poetzelberger Posted October 28, 2019 Posted October 28, 2019 (edited) You have a 90 degree rotation in the map node in 3dsmax. I guess that is was caused the confusion about what you see in 3dsmax viewport and Unigine. The fbx exporter doesnot respect that rotation. The export works as expected, even without the edit poly modifier. ;) Edited October 28, 2019 by werner.poetzelberger
davide445 Posted October 28, 2019 Author Posted October 28, 2019 (edited) The fbx imported in 3dsmax was exported from Revit and imported without any changes. To be 100% sure attached the 3dsmax project with the fbx exported from Revit deleting all the elements except the wall. For me importing this model in Unigine without any modifier result in a wrong orientation. I suppose being both Autodesk products they are reading metadata such as this one in the fbx, that Unigine importer is not reading? Doing all this check and corrections by hand is really time consuming, I know in the gaming sector is all optimized in this way, but there are any tool able to check in the fbx the presence of data not managed from Unigine? There is any Unigine fbx "validator"? RVT_Basic_wall_2019.max Edited October 28, 2019 by davide445
werner.poetzelberger Posted October 29, 2019 Posted October 29, 2019 I guess, that in this case, the texture map specific features (transformations) need to be imported by fbx unigine and translated to the material parameters. Should be possible I guess?. ;)
davide445 Posted October 29, 2019 Author Posted October 29, 2019 Saving the fbx in ascii format I discovered the node Texture: 1937159942528, "Texture::Map #155", "" { Type: "TextureVideoClip" Version: 202 TextureName: "Texture::Map #155" Properties70: { P: "Rotation", "Vector", "", "A",0,0,90.0000025044782 P: "Scaling", "Vector", "", "A",0.181428581476212,0.362857162952423,1 P: "UVSet", "KString", "", "", "UVChannel_1" P: "UseMaterial", "bool", "", "",1 So I suppose with a custom fbx importer will be possible to load also these properties such as the Rotation. Of course I'm not an fbx format expert, there is any documentation to know what Unigine standard importer is exactly loading? Basic_wall_ASCII.fbx
silent Posted October 30, 2019 Posted October 30, 2019 Davide, Quote Doing all this check and corrections by hand is really time consuming, I know in the gaming sector is all optimized in this way, but there are any tool able to check in the fbx the presence of data not managed from Unigine? There is any Unigine fbx "validator"? You can try to use FBX Review (app from Autodesk) and check how it renders your model with texture. Internally it uses the same FBX SDK. I've also tried to import your model to the different engines available on market and they are all displaying your FBX the same way (including UNIGINE). We will see how can we improve the import in the future versions. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted October 30, 2019 Posted October 30, 2019 (edited) I guess, another option would be an importer script to 3dsmax. Or a 3dsmax script, to pass these transformations e.g. from the map to the UVs. Edited October 30, 2019 by werner.poetzelberger
davide445 Posted October 30, 2019 Author Posted October 30, 2019 (edited) 4 hours ago, silent said: Davide, You can try to use FBX Review (app from Autodesk) and check how it renders your model with texture. Internally it uses the same FBX SDK. I've also tried to import your model to the different engines available on market and they are all displaying your FBX the same way (including UNIGINE). We will see how can we improve the import in the future versions. Thanks! Silent I'm not able to make the texture show up in FBX Review (sorry for that), how is appearing to you? Edited October 30, 2019 by davide445
silent Posted October 31, 2019 Posted October 31, 2019 I was not able to get textures working in FBX Review. More likely you need to export them embedded into FBX. I just compared results with other engines with manually assigned dummy texture with a simple text on it. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
