FBX IMPORT
Hello
UNIGINE_API Importer
Can I check if there is no texture file when importing FBX file?
If so, I wonder if there is a way for the user to specify that Texture path. Thank you.
You can get all the textures with ImportScene::getTextures();
This is a code scratch:
Importer *importer = Import::get()->createImporterByFileName("test.fbx"); //creating an importer
ImportScene *scene = importer->init("test.fbx", ~0); // initializing with all available import flags
for(ImportTexture *t : scene->getTextures())
	Log::message("filepath %s original_filepath %s\n", t->filepath.get(), t->original_filepath.get()); //Here you can replace the original paths to the textures
importer->import("../data/1/"); // importing the file in the specified directory
You also can modify FBXImporter source code available in the Engineering SDK edition.
Thank you.
