lightmap Posted November 13, 2019 Posted November 13, 2019 (edited) Hello, Trying to load *.mesh files with 4cc ms11 and found there https://developer.unigine.com/ru/docs/2.9/code/formats/file_formats actually old format description File format identifier (int32 "ms11" ('m' | ('s' << 8) | ('1' << 16) | ('0' << 24)) I can successfully load vertices but cant find out triangle index format, could you actualize format info ? Edited November 13, 2019 by lightmap
fox Posted November 14, 2019 Posted November 14, 2019 Hi lightmap, All in all the description is up-to-date, but there were the following errors in it: 1. File format identifier in all three cases (items 1, 9, 13 in the list) for mesh must be (int32 "ms11" ('m' | ('s' << 8) | ('1' << 16) | ('1' << 24))) Note: for animation the 10th version is used: (int32 "an10" ('a' | ('n' << 8) | ('1' << 16) | ('0' << 24))) 2. Color values in 12 should be (unsigned char[4]). 3. Both Сoordinate and Triangle indices for each vertex of the surface (if num_vertices > 65536) should be (unsigned short[length]). Please note that: All data is in the little-endian notation. float is a 32-bit IEEE754 floating-point type. It has a range of 3.4 e-38 to 3.4 e+38. int here is a compact signed integer. So, to read / write compact integer values use readInt2() / writeInt2() methods respectively. int32 is a signed 32-bit two's complement integer. It has a range of –2,147,483,648 to 2,147,483,647. unsigned short is an unsigned 16-bit integer. It has a range of 0 to 65,535. char is a signed 8-bit two's complement integer. It has a range of -128 to 127. unsigned char is a 8-bit unsigned integer. It has a range of 0 to 255. string must be null terminated. The string size should include this terminating null character. All formats allow multiple surfaces. We'll update the documentation, sorry for the inconvenience caused! Thanks! 1
lightmap Posted November 14, 2019 Author Posted November 14, 2019 Thank you!, so readint2() is something like ((unsigned char)buf[0]) | ((unsigned char)buf[1] << 6) ? if vertices count 24 then it contained in single (unsigned char), if 200 then in two uchars ?
fox Posted November 14, 2019 Posted November 14, 2019 Here, please have a look at the readInt2 implementation for better understanding: int ret = readChar(); int sign = ret & 0x40; if ((ret & 0x00000080) == 0) { ret &= 0x3f; if (sign) return -ret; return ret; } ret = (ret & 0x0000003f) | (readChar() << 6); if ((ret & 0x00002000) == 0) { if (sign) return -ret; return ret; } ret = (ret & 0x00001fff) | (readChar() << 13); if ((ret & 0x00100000) == 0) { if (sign) return -ret; return ret; } ret = (ret & 0x000fffff) | (readChar() << 20); if ((ret & 0x08000000) == 0) { if (sign) return -ret; return ret; } ret = (ret & 0x07ffffff) | (readChar() << 27); if (sign) return -ret; return ret; Thanks! 1
lightmap Posted November 15, 2019 Author Posted November 15, 2019 That's new for me, an interesting way to store int counters in 1 to 5 bytes unigine is nice source of knowledge for me
