luke.errington Posted June 23, 2011 Posted June 23, 2011 We are trying to use the Unigine engine to render several viewpoints, and then blt them to (different locations) in a Windows window (HWND). We will do this for even 16 different renders per update cycle. Following along the lines of that found within the Viewport example, the code looks roughly like (for demonstration): Unigine::ImagePtr src = Unigine::Image::create(); Unigine::Variable src_image(Unigine::TypeInfo(Unigine::TypeID<Unigine::Image *>()), src.get()); Unigine::Variable width(200); Unigine::Variable height(200); g_engine->runWorld("engine.render.renderImage2D", projection, modelview, src_image, width, height, material, hdr); if(src->isLoaded()) { unsigned char *pixels = src->getPixels2D(); Gdiplus::Bitmap b(200, 200, 4 * 200, PixelFormat32bppARGB, pixels); g.DrawImage(&b, 50, 250, 200, 200); } It was expected that the pixels would come back as 0xFFRRGGBB, which is the format that Windows expects, the format that QImage expects (which the example uses), and that expected by far the majority of DirectX formats. However, the pixels actually come back in the format 0xFFBBGGRR. This results in our sky looking red! This same problem applies even if we use: src->convertToFormat(Unigine::Image::FORMAT_RGB8); and Gdiplus::Bitmap b(300, 300, 3 * 300, PixelFormat24bppRGB, pixels); ... which is what the sample code uses, so I don't really see how the sample can work properly. So, is it possible that there is a setting that we can change that will return this in our desired format? Or does anybody know a way to use this data without going through and doing painful byte-swapping between the red and blue components on all pixels? (This isn't hard to do, just inefficient.) More particularly, is this intended? Or a function of the graphics card/DirectX? Thanks, Luke
frustum Posted June 23, 2011 Posted June 23, 2011 There is Image::swap() function which swaps two image channels. Following code converts RGB format into the BGR one. image.swap(0,2);
