IG rain,snow,cloud performance
I
The default snow, rain, and cloud effects of the IG Template (+ VR) cause a lot of frame drop..
I tested with HEMU.
Is there a good way to optimize?
What parameter do you control the size of the rain? aerosol concentration or coverage?
 test cloud -> coverage
rain/snow - > aerosol concentration.
I use Vive Pro.
In VR, if the viewport only renders the aircraft cockpit and my terrain, the frame is already fixed at 45. (Probably between 65 and 75)
If I try to use effects like clouds or snow / rain there, the frame drops to 5 in extreme cases.
Edited by dongju.jeong
aerosol concentration value mast be in [0..1] range
 In future versions, the rain intensity is controlled through a "coverage" parameter.
if you need more intense rain - look at the particle system
ig/weather/fx/rain_particles/nodes/rain_particles.node
you can change in the property PrecipitationParams
min\max spawn rate
min\max density
min\max
image.pngsize
The decal of the rain particle node is not working. (puddles_decal)
I did not modify the decal node.
I don't know what's causing it to suddenly stop working.
pleas help....
I Create a new cigi sample project.
and  tried to make the rain node on the terrain, but the same problem occurred.
Is it a Windows Setting problem?
Hello dongju.jeong,
To fix this, please, change rotation of the puddles_decal node to 0 (x-axis). This will be fixed in the future updates.
