[SOLVED] AppBorder Plugin causes a memory leak (Unigine 2.5)
I have got an older project made in 2.5 SDK (Windows, DirectX11) where I'm struggling with a memory leak caused by the AppBorder plugin.
(The leak itself is easy to see if you have more than 100 fps - just create an empty project and add the AppBorder plugin. The profiler should show an increasing number of Memory and System memory usage.)
Given that the AppBorder plugin is available as source code and has been removed from the SDK for quite some time already, I think it is too much to hope for a bugfix.
But before I dive into the source code, I just want to ask if anyone from the Unigine team has an idea where it is coming from.
Thank you
Helmut
Hi Helmut,
Yeah, the 2.5 is pretty much outdated right now :) I've checked the changelogs and can't find anything related to the AppBorder memory leaks fixing, so I guess you probably will need to dig into it more seriously.
Hello Silent,
thank you very much! Leak is gone. Works perfectly now!
Many thanks,
Helmut
  • silent changed the title to [SOLVED] AppBorder Plugin causes a memory leak (Unigine 2.5)
