[SOLVED] camera far clipping
I'd like to simulate a fighter jet.
After raising the camera up to 15,000 meters(the highest altitude of the fighter),  I can't see far around.
I think the maximum viewing distance is 26000.
Can I make it look farther?
playerSpectator->setZFar(num);
The zfar seems to be the limit of 26000.( test in editor using Far Clipping parameter)
Can I see farther?
When you generate your terrain via Landscape tool you have an ability to set the maximum visibility distance to the generated ObjectTerrainGlobal:
This can't be changed in runtime, so if you generated terrain with 60 km visibility distance it will stay forever. So to fix this you need to generate a new terrain with increased visibility distance.
This problem was related to distance of haze.
thanks.
  • silent changed the title to [SOLVED] camera far clipping
